The Big Rubber VS Polyurethane ?????
Postby Camshaft1987 » Mon Mar 14, 2016 9:38 pm
Wow this site has an amazing amount of information from super knowledgeable people, much appreciated.
To start off I have a red st165 with a supposed 205 trans I have yet to ID shifts well though, supposed twin entry turbo with manual boost control playing with 13-14psi, 3in cat back exhaust, interior gutted, relocated bat. an absolute blast to drive, pulls like a mule... above 3500rpm pretty healthy engine no blow by and good vacuum . This old girl definately needs some lovin though. Needs tbelt, bushings in the rear(poly or rubber :shrug: ) , radiator with a pinhole in it, a bunch of wiring fixed (stupid key off loads), paint is just awful body panel clips broke.
My questions.
1---How to ID the trans if possible cant find a stamp or casting. I think it has the electronic speedo cuz PO said that they didnt match up/doesnt work. Cant even see the bastard where it plugs in.
2---How to ID the turbo w/o rippin it out. Havnt drivin many turbo cars to say what is a fast spool or not to be able to tell since twin entry seems to have less turbo lag.
3---Safe limitations of power and boost with factory internals. I heard there are intake cams from other toyotas that work well without overlap.
I'm pretty new to toyotas but have a good 10 years of wrenchin under me to figure stuff out. Could not pass up on this Alltrac. Anyway thanks for any info guys.
Camshaft1987
Re: The Big Rubber VS Polyurethane ?????
Postby Camshaft1987 » Mon Mar 14, 2016 9:39 pm
Oh ya Rubber Or Polyurethane or both :shrug:
Camshaft1987
Postby CorticalStack » Mon Mar 14, 2016 9:48 pm
I couldn't tell you how to ID your hardware or what kind of boost you could run (I would imagine that would depend very heavily on the condition of the motor as well), but as far as bushings are concerned, from my research on the forum it seems like "Both" is the way to go.
Specifically rubber in the rear control arms (1 and 2) -- more info on that in this thread here:
viewtopic.php?f=8&t=21366&start=45
You are a child of the universe.
No less than the trees and the stars, you have a right to be here.
And whether or not it is clear to you, no doubt the universe is unfolding as it should.
~Max Ehrmann, Excerpt from Desiderata (1952)
CorticalStack
Images: 34
Postby underscore » Mon Mar 14, 2016 10:15 pm
I think you can ID the turbo by looking at the number of bolts used to secure it to the downpipe, but I'm not positive. A quick search on here should tell you.
Postby RedCelicaTRD » Tue Mar 15, 2016 2:44 am
You can ID the trans by looking for a mode selector on the transfer case. St205 doesn't have a selector, 165 and 185 do.
As already mentioned, ID the turbo by the number of studs holding the down pipe to the turbo.
What ecu are you running? That will determine how much boost to run.
Postby FC Zach » Tue Mar 15, 2016 10:15 am
Camshaft1987 wrote:2---How to ID the turbo w/o rippin it out. Havnt drivin many turbo cars to say what is a fast spool or not to be able to tell since twin entry seems to have less turbo lag.
Turbos have identification numbers casted on them:
74020 for twin entry Ceramic CT26
74030 for twin entry Inconel CT26
74040 for twin entry Ceramic CT20B
74080 for twin entry the steel shaft CT20B from the ST205 WRC
Example:
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby FC Zach » Tue Mar 15, 2016 10:24 am
For a fourth gen:
74010 for single entry ST165 All-trac.
FC Zach
Images: 9
Postby Camshaft1987 » Wed Mar 16, 2016 1:09 am
It has the single entry factory turbo identified by the four studs instead of 6, Got that....
It has the factory ecu st165. Need to know if 14psi is too much ie. engine maps keeping good a/f ratios. The engine is in pretty good health with 20 pounds of vacuum and hardly any blow by no smoke. Obviously want to make it last as long as possible but still have a nice grin factor hehe... Need some really good boost and a/f guages now. Any opinions welcome on what kind.
where is the "tranny selector" located whats it look like little lost there.
Both rubber and poly makes sense. Stiff where you want it flexy where you dont.
Thanks guys.
Camshaft1987
Postby RedCelicaTRD » Wed Mar 16, 2016 2:49 am
viewtopic.php?f=50&t=51202&start=0
That post is talking about an RC trans, but both the RC and st165 (and 185) have the mode selector while the 205 does not.
Postby TTEETT » Wed Mar 16, 2016 3:03 am
I have always preferred Rubber over Polly.
In my experience its far more durable and reliable.
2c
TTEETT
Postby Camshaft1987 » Wed Mar 16, 2016 10:27 am
i'll have to look and see about that selector tomorrow.
Any Northwest seattle tacoma trac owners here
Camshaft1987
Postby Camshaft1987 » Wed Mar 16, 2016 10:35 am
its a 205 trans. i was wandering what the hell that little vent was for sweeet!!!!
Camshaft1987
Return to New Member Forum
