mohsin univrsal
New member
planning to build the engine for around 500 wheels
the engine is currently on hx35 turbo and hks ssqv bore engine management is link g4+
intercooler and internals are stock the stock rods,crank and bearings can handle 500 wheels as much as i know
do i need to change the intercooler ? :doh:
so i would need pistions for block and a head built should be done
Brain crower 272 cams/spring retainers are better or should i use another cams? like hks kelford or any other? need recommendations......
i will switch to gt35r turbo , omni 4 bar map and fic 1450 fuel injectors and aeromotive 345lph fuel pump.. these things i have in my mind,
any help or suggestion will be highly appreciated.
