90 alltrac headgasket
Postby tractor1 » Thu Jul 21, 2016 1:08 am
HI does any one have a oem head gasket they wold like to sell cheap. I do not wont to plane my head and block for a metal one. Thanks I live in ny.
tractor1
Re: 90 alltrac headgasket
Postby ___Scott___ » Thu Jul 21, 2016 11:59 pm
If your block and head are flat and just need a little clean-up, you can do that with sandpaper and a flat block of aluminum. Just be mindful of how much material you are removing and make sure you take about the same amount everywhere. I used 320-grit when I did mine and the Cometic MLS gasket I installed appears to be sealing just fine.
I did the same thing to my old ST165 about 10 years ago and it has held a seal ever since. (That engine has other problems now, but is thankfully in the hands of a new owner.)
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby jlspec » Sun Jul 24, 2016 6:51 pm
Why don't you just check with Toyota or www.toyotapartsestore.com?
jlspec
Return to New Member Forum
Users browsing this forum: Bing [Bot] and 1 guest
