Wiring problem
Wiring problem
Postby wabbajack967 » Sun Nov 27, 2016 2:41 pm
I just bought a st185 celica without the engine because the previous owner broke it. i bought a 3sgte engine and put it in. My problem is that the car doesnt start! I turn the key but the starter doesnt work, however i tried to give the input to the starter manually and it works, the engine starts but when i took of the wire that i used on the starter it stops working.. i checked al the relay and fuse! I Aldo noticed that when i turn the key my turbo pressure signal goes to the max but my map sensor is unplugged. Someone has an idea?
wabbajack967
Re: Wiring problem
Postby ___Scott___ » Sun Nov 27, 2016 6:38 pm
The problem is common among old Toyotas. The fix is commonly referred to as the "starter relay mod." In this post: viewtopic.php?f=10&t=31416&p=469496&hilit=starter+relay+mod#p470669
there is a link to another forum that goes over the problem and the fix. I'll repost that link here: http://www.st162.net/forum/showthread.p ... r-Problems
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Re: Wiring problem
Postby Nitro_Alltrac » Wed Nov 30, 2016 12:13 am
This definitely works. Did it to mine.
Mike
92 All Trac - Daily Driver
Nitro_Alltrac
Return to New Member Forum
