front strut
front strut
Postby tractor1 » Wed Dec 07, 2016 11:43 pm
Hi I was pulling apart my front struts to paint them and found oil in the housing. From what i can find this is normal. NO leaks, lost a little oil, can I put some back in? Any one know what oil, how full or how much to put in. thanks
tractor1
Re: front strut
Postby eric thompson » Thu Dec 08, 2016 7:56 pm
In the housing?? Did you unscrew the large glan nut that surrounds the shaft?
Sent from my XT1650 using Tapatalk
ST165-PARTS-RED
NEED ONE MORE FOR STREET:)
https://www.youtube.com/watch?v=w-RCuV_Hmqk (ITS miata 6spd,4.78 rear, shitloads of fun!! multiple wins and track records in 2014)
eric thompson
Images: 6
Re: front strut
Postby tractor1 » Thu Dec 08, 2016 9:10 pm
Yes it was in the housing and yes I took off the big nut, wonted to make sure it would come off without heat.
tractor1
Re: front strut
Postby eric thompson » Thu Dec 08, 2016 9:14 pm
The OEM housing is a gas pressurized strut as is probably stamped on the side... Don't think refilling will feel the same. You can install strut insert cartridges. Similar to a shock inside a strut...
ST165-PARTS-RED
eric thompson
Images: 6
Return to New Member Forum
