I need this part
I need this part
Postby Heat » Fri Dec 16, 2016 3:21 pm
Hello,i have a celica all trac 1988 and i need the fuel tank
Heat
Re: I need this part
Postby mkernz22 » Fri Dec 16, 2016 4:26 pm
Good luck with finding it, not easy to come by..
mkernz22
1995 Toyota Celica
Postby Heat » Fri Dec 16, 2016 4:59 pm
Thanks!!! :) im actually feeling lucky.btw if you have this model and need parts let me know i have extras.
Heat
Postby Nitro_Alltrac » Sat Dec 17, 2016 12:46 am
I've seen a few 185 tanks floating around lately but the 165's look to be few and far between.
Mike
92 All Trac - Daily Driver
Nitro_Alltrac
Postby Heat » Sat Dec 17, 2016 1:58 pm
Know of any shop that can fabricate one that fit?
Heat
Postby Nitro_Alltrac » Sat Dec 17, 2016 5:34 pm
If there is anything left of your old one to use as a pattern, a good local fab shop should be able to put one together.
Mike
Nitro_Alltrac
Postby Heat » Sat Dec 17, 2016 6:01 pm
No... my other one is not 4wd.the fuel tank as you may know is placed in the center not at the end and is completely different:/
Heat
Postby Nitro_Alltrac » Sat Dec 17, 2016 6:51 pm
Yes, I know about the difference.
So you have a All Trac but no fuel tank? That will make fabrication a little harder.
By other one, you mean you have a FWD parts car or other Celica?
Mike
Nitro_Alltrac
Postby Heat » Sat Dec 17, 2016 7:40 pm
Yes,the awd is the one im missing the tank.the regular coupe i have it for parts.
Heat
Postby Kurt_st185_gt4 » Mon Dec 26, 2016 6:01 am
Heat wrote:Hello,i have a celica all trac 1988 and i need the fuel tank
Found this one with car-part.com I haven't used the service before as I prefer the local pull-a-part because of the pricing (paid $35 for an entire knuckle assembly with the hub still in vs $35 for just a used hub from car-part or $120 for just a new hub) but I heard they can and will ship parts.
Kurt_st185_gt4
Postby Nitro_Alltrac » Mon Dec 26, 2016 12:58 pm
It would be worth checking. I've used the site before and had very good luck with the yards that list there.
Mike
Nitro_Alltrac
Postby Heat » Mon Dec 26, 2016 1:04 pm
Im on the phone whit them rigth now!!!
Heat
Postby zaluss » Mon Dec 26, 2016 3:44 pm
Heat wrote:Im on the phone whit them rigth now!!!
I would be cautious as the picture is clearly a FWD convertible which has an entirely different gas tank.
zaluss
Postby Heat » Mon Dec 26, 2016 4:10 pm
U sure? I didn't knew that :(
Heat
Postby Nitro_Alltrac » Mon Dec 26, 2016 5:12 pm
The tank will have to be from an All Trac or a GT4.
Mike
Nitro_Alltrac
Return to New Member Forum
