90 alltrac idle
90 alltrac idle
Postby tractor1 » Wed Jan 04, 2017 11:11 pm
HI guys I have just got my car running and have some questions. The main problem I have is the idle is very high, as in it goes from 1700 to 2000 rpms in a cycle. Starts at 1700 and slowly goes up to 2000 and then drops to 1700 and then starts all over. My air fuel meter says it is very rich if it is right. Could my cold start injector be stuck on? Can I just unplug it to see if it gets better. I have no engine light on, is there codes if it is not on?
tractor1
Re: 90 alltrac idle
Postby FC Zach » Thu Jan 05, 2017 8:45 am
Vacuum leak?
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Re: 90 alltrac idle
Postby tractor1 » Thu Jan 05, 2017 9:05 pm
I got 20 inhg on my vac/pressure gauge at idle, which it is idling high.
tractor1
Re: 90 alltrac idle
Postby Andy » Fri Jan 06, 2017 8:00 pm
Idle Speed Control Valve is likely bad.
test it per bgb.
Or, you might try pinching/valving off the air feed to it to see if that pulls the idle down like the ISP valve should.
Andy
Re: 90 alltrac idle
Postby tractor1 » Sun Jan 15, 2017 5:16 pm
Yes that was the problem, thank you very much
tractor1
Return to New Member Forum
