New member
New member
Postby rallywrc » Mon Jan 23, 2017 12:51 am
Hi
I am new to the Forum,i am in New Jersey i have a 91 gt4 sitting for 3 yrs needs a motor i have a 3gen motor and trans from a wrc verson i didnt get time to do the swap as yet planning to do it this year,I just want to say Hello to the members on the Forum.
rallywrc
Re: New member
Postby Kurt_st185_gt4 » Mon Jan 23, 2017 3:44 pm
rallywrc wrote:Hi
Welcome to the forum. Good luck on the swap. Do you have any plans to build the gen3 motor while its still out of the car?
Kurt_st185_gt4
Re: New member
Postby rallywrc » Tue Jan 24, 2017 1:02 am
I was planning on changing the camshafts and turbo,whats your opinion on the stock internals ? can i change the cams & valve springs without doing anything else to the valve train it looks like the biggest problem with the swap will be the wire harness & the intercooler if i go with front mount & if i decide to keep the water to air i will have to buy a heat exchanger,pump & hoses i didnt get those when i bought the engine.
rallywrc
Re: New member
Postby Kurt_st185_gt4 » Tue Jan 24, 2017 1:30 am
I wouldn't do cams unless you're buying aftermarket ones. As far as stock internals go I believe most just do cams and turbo swaps. However most blocks after 94 were made with a cheaper quality iron. Will you be using the gen2 ecu to run the gen3?
Kurt_st185_gt4
Re: New member
Postby rallywrc » Tue Jan 24, 2017 1:46 am
I didnt know the newer blocks were made cheaper,i would have keep the gen 2 motor but when i purchase the car the motor was bad it had overheated from the previous owner,i am going to use the gen3 ecu
rallywrc
Re: New member
Postby rallywrc » Tue Jan 24, 2017 1:48 am
Do you have a 3gen swap also ?
rallywrc
Re: New member
Postby Kurt_st185_gt4 » Tue Jan 24, 2017 2:03 am
No swaps here. I have a euro st185 with the 151f tranny same as the carlos sainz (rear lsd). How bad was the overheat?
Kurt_st185_gt4
Re: New member
Postby rallywrc » Tue Jan 24, 2017 3:00 am
I didnt take the motor apart,but i notice when i started to take things loose to remove the motor areas around the cylinder head & where the hoses & connectors show sign of a white color corrosion leak thats been dried up almost like the motor builds up too much pressure at some point & coolant starts to force its way out i dont really know how to explain it will 2gen block works on a 3gen head ?
rallywrc
Re: New member
Postby Kurt_st185_gt4 » Tue Jan 24, 2017 3:34 am
Yes a gen3 head will work on a gen2 block. Although the gen2 head flows better than the gen3 the shimless buckets and better flowing intake manifold make it worth it if you're keeping those parts stock. Also I want to say parts for the gen3 head are more expensive than a gen2 head such as cams and manifolds.
Kurt_st185_gt4
Return to New Member Forum
