90 alltrac losses injector pulse
Postby stlalltrac90 » Sat Feb 11, 2017 12:20 am
90 alltrac losses injector pulse after initial start up with maf plugged in and when its (maf) is unplugged just runs badly
stlalltrac90
Re: 90 alltrac losses injector pulse
Postby mx6er2587 » Sat Feb 11, 2017 6:52 pm
I've seen loose injector wires at the ECU cause similar problems. Has the ECU plug been messed with recently?
mx6er2587
Postby stlalltrac90 » Thu Feb 16, 2017 12:04 am
Found it
Ground wire to air temp sensor was bad somewhere in harness
stlalltrac90
Return to New Member Forum
