1990 Celica AllTrac turbo owner from florida!
Postby Alltrac_Angst » Mon Mar 20, 2017 3:52 pm
I own a 1990 Toyota Celica AllTrac Turbo that I bought close to a year ago that I would like to get running now that I have the time and (some) money . My car does NOT run at the moment due to the abuse the previous owner put it through. Hillybilly's + Alltrac + 10 acres = you get the point. Essentially i'm posting on the new member thread because I want access to the vast amount of information this website holds, but I also have some questions maybe some of you could answer for me (please) lol.
I've taken a look or 15 and repaired some things on the car like the fuel tank and oil pan because they were leaking. The radiator and fan looked like it came off an old Mazda truck and upon removing it and the hoses, there was red Georgia clay ALL UP IN THAT THANG. That's not the only thing keeping this car from running either. Wiring looks like dog shit with strands of hay in it, and there's various bolts and brackets missing from the motor (shade tree at it's finest). No rust and a clean interior and body are what keep my future dreams or race car-ing alive. I bought the car not because of how it ran, but the potential I saw in it.
Finally, the questions.
1. Should I just rebuild this mess of a 3S-GTE?
2. Where should I start building if I wanted to replace stock parts on the motor with performance parts? I have plenty of time to do all the work, but i'll have to buy these items part-by-part and do a lot of unbolting old and bolting on new.
3.If any of you have a good parts website that I can browse for parts that you wouldn't mind sharing, that would be greatly appreciated.
Thanks, Josh.
Alltrac_Angst
Re: 1990 Celica AllTrac turbo owner from florida!
Postby Corey » Fri Mar 24, 2017 6:07 pm
Hi Josh, welcome to the club
For aftermarket parts you can look through these off the top of my head:
http://www.koracing.net
http://www.twosrus.com
http://www.fensport.co.uk
http://www.rhdjapan.com
http://www.xiiimotorsports.com/ (club member run)
http://speed-source.net/
For OEM Parts, there are a number of dealers in the US who run internet stores on the side, usually with far lower prices
Here are a couple I can remember:
https://www.lithiatoyotaparts.com/partl ... eid=215542
http://toyota.partswebsite.com/
And for finding used parts, in addition to this forum we have:
http://www.gt4oc.net
http://www.gt4dc.co.uk
http://www.mr2oc.com
And for owners manuals and big green books:
http://gt4.mwp.id.au/ (member run site)
And this is a great resource for searching OEM part numbers and diagrams:
http://www.toyodiy.com/
For a good read on upgrading the 3S-GTE, see here:
http://www.mrcontrols.com/primers/power.htm
Cheers
Corey
Images: 50
Postby underscore » Fri Mar 24, 2017 8:33 pm
For rebuilding vs replacing, I'd say that depends on your patience vs your budget. In my experience it's a lot easier to completely remove anything that was hacked apart by someone else and redo it properly. I'd start by replacing the mangled harness and seeing how well the engine runs. If the internals seem good just pull the motor, clean it up a bit, and reinstall it, so you know a motor mount isn't missing half the bolts or something.
Postby Alltrac_Angst » Mon Mar 27, 2017 12:19 pm
Corey wrote:Hi Josh, welcome to the club
Cheers
Corey, thanks for your help with the websites. They do have a lot of useful information that I've used so far! Prices aren't bad either :D
Alltrac_Angst
Postby Alltrac_Angst » Mon Mar 27, 2017 12:22 pm
underscore wrote:For rebuilding vs replacing, I'd say that depends on your patience vs your budget. In my experience it's a lot easier to completely remove anything that was hacked apart by someone else and redo it properly. I'd start by replacing the mangled harness and seeing how well the engine runs. If the internals seem good just pull the motor, clean it up a bit, and reinstall it, so you know a motor mount isn't missing half the bolts or something.
underscore, Thanks for the advice. I'm going to pull the motor and clean it up and tidy up the wiring while I have the motor out. I'll send pics of everything once it's done or close to being done!
Alltrac_Angst
Postby GT4times2 » Wed Mar 29, 2017 5:46 am
Welcome to the forum. Where in Fla are you? Good to see another All Trac in the South. What color is your car? Any pics to share? I'd look into a later Gen engine and swap it versus building. Depending on your goals, of course. But there are many advantages to getting a 3rd or 4th Gen swap. Cheaper than building your 2nd gen motor. Send me a PM when you can.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Return to New Member Forum
