Alltrac roller piecemeal
Postby Camryshamry » Fri Apr 14, 2017 4:03 pm
So I am trying to get a 88 all trac back up and running so for replacing the missing motor and trans could camry drive parts work out even a 3sfe I just want a awd celica running doesnt mean it will stay wimpy forever just to get it moving on its own again. I found a guy with two 3sgte motors from mr2s but I doubt they line up
Camryshamry
Re: Alltrac roller piecemeal
Postby MrMcQuacker » Sat Apr 15, 2017 4:43 pm
If you have a 88 Alltrac, a 3sge motor is a direct drop in. And I am not 100% sure. But iirc, the 3sfe should be a drop in as well, due to it being an S series. Wiring is going to be your homework, Or you can send it to the wire guru's we have on the forums here.
GL
MrMcQuacker
Postby Ryan » Sat Apr 15, 2017 4:50 pm
in my opinion its not really worth your time, the amount of wiring you'd have to do you could just do a 3rd or 4th gen swap and pay slightly more. A 1st gen motor would be best if you have existing wiring.
-Ryan
Ryan
Return to New Member Forum
