speedo and tach not working
Postby Wilm_alltrac » Sun May 21, 2017 3:31 pm
So a few months i noticed my tachometer was not working as well as it should. When first started in cold weather the tach would be very weak and show only about 1000rpm when it should show around 4500rpm. It didnt bother me much because once it warmed up it would be a bit more accurate but now it is acting like that regardless of weather. In addition to the tachometer not working well the speedometer does not work at all, as well as the odometer and the cruise control. I had the cluster out to check all the capacitors and they arent broken or bulged on the top so im not sure if they can still be bad or not but if anyone has any ideas of what it could be i will hear anything.
2016 Hyundai Genesis coupe Ultimate
1992 Toyota Celica All Trac
Wilm_alltrac
Re: speedo and tach not working
Postby FC Zach » Sun May 21, 2017 6:37 pm
Speedometer:
1. Check cable
2. Check gear on trans. Either one of these are bad
Cruise:
1. Fix speedometer issue
2. Check speed sensor and actuator (use manual for Instructions and specs)
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby Wilm_alltrac » Sun May 21, 2017 6:40 pm
i have looked all around the transmission and the firewall and cannot find the speed cable or where it goes into the transmission.
Wilm_alltrac
Postby FC Zach » Sun May 21, 2017 6:43 pm
It's tight in there, good luck. Prepare for scratched hands/arms
FC Zach
Images: 9
Postby FC Zach » Sun May 21, 2017 6:46 pm
Wilm_alltrac wrote:i have looked all around the transmission and the firewall and cannot find the speed cable or where it goes into the transmission.
Look under coil/ beside heater valve.
FC Zach
Images: 9
Postby Wilm_alltrac » Sun May 21, 2017 7:00 pm
yeah anytime i work on it the result is bloody knuckles and scratched forearms. but i appreciate the help ill check it out.
Wilm_alltrac
Postby mx6er2587 » Mon May 22, 2017 6:45 pm
for the tach the capacitors are almost certainly bad in the cluster. Mine were not bulged when I replaced them last year but had failed.
mx6er2587
Return to New Member Forum
