3SGE > 3SGTE Swap
3SGE > 3SGTE Swap
Postby Pascalvg » Tue Oct 24, 2017 5:36 pm
Good afternoon,
My car is a 1991 Toyota Celica T18.
Recently I swapped my 2.0 GTI engine for a 2.0T (3sgte).
Now I got a problem with the wiring to the ECU. Because the harness of the turbo engine was cut. I do not have the plugs of that one so I kept my old harness. All plugged in well (needed to modify the plugs for the injection a little). The only problem is that the pinout of the 3sgte ecu and the 3sge harness is different.
I want to change the wirering on the plugs but maybe you guys have a better suggestion. Like a pre-made adapter to get the right connections.
This is the product part of the 3sge ECU:
89661-20720
This is the product part of the 3sgte ECU:
89661-2B840
Other suggestions are welcome.
Thanks,
Pascal :notworthy:
Pascalvg
Re: 3SGE > 3SGTE Swap
Postby Pascalvg » Fri Oct 27, 2017 3:00 pm
Bump!
Pascalvg
Return to New Member Forum
