Just signed up and I'm looking for advice
Postby Blue_andthe_Grey » Sun Jan 21, 2018 5:20 pm
Hello fellow all-trac owners! I've had my 91 corolla DX wagon (4A-FE engine) for about 5 years now. Got it from the original owner with only 95k miles on it. I've made some modifications but I'm looking to get a little more power out of the engine.
I have put a custom performance muffler on and thats about it. What else can I swap out on the car to get a little more power? Please use laymans terms as I'm quite new to car modification!
Blue_andthe_Grey
Re: Just signed up and I'm looking for advice
Postby FC Zach » Sun Jan 21, 2018 8:35 pm
Install a 4A-GZE or a 20 valve 4A (can be found on eBay), really anything but the FE engine.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby Blue_andthe_Grey » Sun Jan 21, 2018 9:37 pm
Whats wrong with the FE? Its been incredibly reliable so far, I've road tripped all over the US.
Blue_andthe_Grey
Postby FC Zach » Sun Jan 21, 2018 11:56 pm
Reliable yes but when it's more power you want, it's lacking.
FC Zach
Images: 9
Postby underscore » Mon Jan 22, 2018 1:01 am
Even just a normal 4AGE should make a difference. F heads are for economy, G are for performance.
Postby FC Zach » Mon Jan 22, 2018 1:19 am
underscore wrote:Even just a normal 4AGE should make a difference.
Would be more 'plug-and-play' too. . On top of that, (depending on where the OP is located) there is more aftermarket support for an older 4AGE as opposed to a Silver/Blacktop in the states.
FC Zach
Images: 9
Postby Blue_andthe_Grey » Mon Jan 22, 2018 2:27 am
Being that replacing my engine is both out of my zone of expertise and out of my budget, are there any suggestions for increased performance on the 4A-FE?
Blue_andthe_Grey
Postby FC Zach » Mon Jan 22, 2018 3:15 am
In that case I would say look for a header and drop in (K&N style) filter that'll work for you application. . If you don't see a header for you app, I'm sure one could be fabricated to fit. On my first Celica (a '94 ST w/ a 7Afe) I recall modifying a Corolla header to work.
FC Zach
Images: 9
Postby Blue_andthe_Grey » Mon Jan 22, 2018 4:39 am
Thanks! After some research it seems that a cold air intake and header is the right direction to go. I appreciate your input.
Blue_andthe_Grey
Postby underscore » Mon Jan 22, 2018 8:54 pm
A good tune up can help a lot too. Fresh fuel filter, plugs, wires, cap & rotor, O2 sensor and having the injectors cleaned can bring back some of the power lost over the years.
Postby turbo4wd » Mon Jan 22, 2018 9:34 pm
underscore wrote:A good tune up can help a lot too. Fresh fuel filter, plugs, wires, cap & rotor, O2 sensor and having the injectors cleaned can bring back some of the power lost over the years.
THIS... I purchased a 99' 4Runner recently and did all of the basic maintenance items listed above as well as all of the fluids and the difference in drivability was night and day.
Dan
Undercover Moderator
turbo4wd
Return to New Member Forum
Users browsing this forum: Bing [Bot] and 1 guest
