G-Games 77W 18x8.5+30mm and 18x9.5+20mm preview
Post your experience with sellers on this forum
Postby magnum » Sat Mar 21, 2009 9:10 pm
Well I tried a test fit today of my wheels now that I have tires and just like I thought I'm going to need to pull the rear fenders a bit and run a little camber to make them fit. On a narrow body like mine this is the absolute most tire and wheel you can fit in the rear. I'm running 245/35ZR18 in the rear and 215/40ZR18 in the front. The front may need a little more camber but not much. I will wait to pull the rear fenders until the weather warms up a bit and the streets are clear of snow.
magnum
Postby celicaGTS_T » Sat Mar 21, 2009 10:30 pm
Looks good
celicaGTS_T
Postby camry90 » Sun Mar 22, 2009 1:01 am
you don't care that the different tire size ruins your center diff?
camry90
Postby CMS-GT4 » Sun Mar 22, 2009 2:14 am
If the rolling diameter is the same the diff should be fine.
Looks promising. I am wondering how well those rear would fill the flares of a widebody.
Postby WarTowels » Sun Mar 22, 2009 2:57 am
Those tire sizes are very very very similar.
Pat, with what... 700+ hp ran staggered stance and was just fine.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby celicaGTS_T » Sun Mar 22, 2009 3:57 am
ditto on the wide body... it jus looks right 8)
celicaGTS_T
Postby camry90 » Sun Mar 22, 2009 4:35 am
CMS-GT4 wrote:If the rolling diameter is the same the diff should be fine.
yeah you are right, i check the tire diametre and it's the same... sorry my bad
camry90
Postby magnum » Sun Mar 22, 2009 5:32 am
Anyone with a wide body that wants to come by and try them are free to.
magnum
Postby lumbercis » Sun Mar 22, 2009 2:37 pm
Someone with a widebody should go do a test fit. It would be good for the community to have a "verified good" fitment for these widths.
Caldina powered...
lumbercis
Postby magnum » Sun Mar 22, 2009 5:53 pm
Conrad is the only one I can think of that lives close to me.
magnum
Postby smog7 » Tue Apr 14, 2009 4:56 am
WarTowels wrote:Those tire sizes are very very very similar.
-Towels
I bet he hardly ever drives his car...
and if he does its for a couple of seconds in a straight line....
-omar
rally tarmac 1990 st185
smog7
Postby WarTowels » Tue Apr 14, 2009 5:00 am
Speculation. He designed the car to be a capable straight line and twisties- that's what he said on his site. Regardless, the load he puts on the parts is incredibly higher than they were designed for, and seem to be just fine.
Plus the rolling diameter of those tires is like <1% different. The realised grip difference would be relatively small I'd guess.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Return to Seller Reviews
