1990alltrac
New member
Just woundering if there was any time frame on a dp back. I'm almost done with my car and need exhaust now. I can hold off if you have any idea on when one will become available...
Are you referring to the front pipe where it goes over the crossmember?KORacing":1mfodv0n said:No issues with it to date, but the amount of time CodingParadox has been able to run it has been limited as his motor went out. I haven't had time to arrange for him to bring it back and let me do some fixturing, but man, it was very tight to route the 3" system in that car! I worry about very small tolerance stackup leading to rubbing issues and am unsure, yet, how I will solve that potential problem.
KORacing":1iy7v4gc said:Right now the system is full SS from the downpipe back. It wouldn't be made to work with the aussie system in part or whole. I will probably start a group buy toward the end of the year, and the cost would be under $1k. If I can get a mild version of it to work out, it would probably be at least 300 less than the SS version. I still have a few bugs to work out on the prototype that David has on his car as is.
KORacing":1zzschqd said:It probably will be a single tip design like I used on David's prototype. The tip is 4" and can utilize a silencer to make the exhaust even quieter. There may be a possibility to use various mufflers, but finding nice quality, good performing mufflers, and a 3" inlet with a dual tip outlet isn't easy.
