Downpipe isn't done yet - hopefully by next weekend.
Here are the pictures of the parts I had ceramic coated so far at Polydyn. I do a lot of business with them through my NA header porting & polishing business so I was expecting nice work, and boy did I get it - they do a great job.
All parts:
All parts 2:
The manifold below has had the inlet and outlets opened up and reshaped and polished to work properly with the ported head with oversize valves.
Manifold:
Adapter:
Turbine Housing
Notice below that you won't see any of the flange from the turbo inlet anymore. I opened it up and polished it to make sure there would be no restrictions to flow.
Adapter and turbine housing inlet:
On the adapter to manifold views below you are looking upstream through the adapter at the manifold outlets. Because there is some room for movement when tightened I opened up and polished the inlet for the adapter at least 2m wider than the manifold outlet all the way around to ensure there won't be any edges sticking into the exhaust flow when I put them together. The manifold outlet has also been opened up a bit, reshaped and polished.
Adapter and Manifold:
Adapter and manifold 2:
The clearance on the turbine to housing has tightened up a hair so it should improve spool quite a bit when combined with everythign else thats been done.
Turbo turbine view:
Turbo turbine view 2:
Turbo compressor housing view:
Turbo inlet & outlet view:
All parts:
All parts 2:
Manifold:
Adapter:
Turbine Housing
Turbo turbine view:
