More info here: http://www.alltrac.net/phpBB2/viewtopic ... 839#201839
Relevant mods:
2.2L stroker, CP pistons (8.5:1), Carillo rods, OS valves, 272 HKS cams (110LC intake, 109.5LC exhaust), custom intake manifold, Ford TB, FMIC w/ 4" thick core, stock ignition, Accel plug wires, NGK iridium plugs (1 heat range colder than stock -- .022 gap), ARP head studs (standard 10mm), TTE 1.4mm head gasket, head/block lapped to 600grit with KO's Sonic lapping tool, KO Racing SB35R w/ .63 A/R housing, KO Racing custom exhaust, KO Racing custom 2.5" aluminum IC pipes, Tial BOV, ACT 6 puck clutch, Hydra Nemesis tuned by Kris at KO Racing, KO Racing 8mm bored stock rail (dual feed), Sard 800cc injectors, Aeromotive FPR (55psi static), walbro fuel pump.
520whp on race, 406whp on pump.
Relevant mods:
