Old Camry AllTrac with a Heart of Platinum
Camry All Trac, Previa All Trac
Postby TOYRACR92 » Sun May 21, 2006 3:37 pm
Ok well a Friend of mine has finnally finished his
1990 Camry AllTrac Proj
it has all the Drivetrain of a 97 Celica Alltrac
The 264bhp 3SGTE Motor has been Strengthen with new Forged Pistons and rods, ported Head, ACT clutch, Fidanza Flywheel, 3"custom Downpipe all the way thru to the N1 Muffler. Custom Intercooler Plumbing, F
its even a bit more quicker with HKS F-Conn piggy back unit.
All the 97Celica AllTrac Rotors and Calipers are on it. Also the Celica Gauge Cluster has been Fabbed in.
This is a NIce Sleeper and alot of Fun
http://www.MySpace.com/HuxRacing
TOYRACR92
Postby CMS-GT4 » Sun May 21, 2006 4:02 pm
Thats a cool little car. I think some black wheels would be fitting, and maybe coating the IC black. That way no one would have any idea of what was coming. :evil:
Postby Gary ST165 » Sun May 21, 2006 4:10 pm
:sleeper mode:
reminds me of: Image I pity the fool!
:sleeper mode:
Great project 8)
ST165 turbo 4WD
Gary ST165
Postby alltracman78 » Wed May 24, 2006 12:45 am
Not bad, but a hood scoop and a huge fmic hardly qualify as "sleeper".
:D
Rust ?
Postby GMan » Fri May 26, 2006 11:53 pm
I have not seen many, if any; Camries without rust.
Needs a few dents & dings and a bit of dirt, and it will be Invisble. :-)
Cool project !
Regards;
GMan
Postby wizzards581 » Thu Jul 13, 2006 1:48 am
camry's i seen dont have rust. my family have a few and no rust.
-03 matrix XR
wizzards581
Postby Gary » Thu Jul 13, 2006 2:00 am
wizzards581 wrote:camry's i seen dont have rust. my family have a few and no rust.
That's because they don't use salt on the road in CA. :wink:
93 ST185
Gary
Postby Brandon24pdx » Thu Feb 15, 2007 4:39 pm
Any tech info about swapping a 3S-GTE into one of these 88-91 All-trac Camrys available anywhere?
Brandon24pdx
Postby 2RM » Thu Feb 15, 2007 11:37 pm
I have seen a Turbo 4WD Camry before but it was a diesel and it was in Europe. :P
2RM
Postby alltracman78 » Wed Apr 18, 2007 11:45 pm
Brandon24pdx wrote:Any tech info about swapping a 3S-GTE into one of these 88-91 All-trac Camrys available anywhere?
Should be pretty cake.
They came stock with the 3SFE, so same family.
Mechanicals should bolt right up.
You probably want to use a Celica Alltrac trans, if the prop shaft and driveshafts will bolt up to it.
Wiring will be the hardest part most likely.
Postby Mafix » Thu Apr 19, 2007 12:55 am
actually if you stick to a gen 2 motor (1990) it should drop right in with a GTE harness and plug and go.
Postby TheAutoholic » Thu Apr 19, 2007 1:29 am
Mafix wrote:actually if you stick to a gen 2 motor (1990) it should drop right in with a GTE harness and plug and go.
Really?
Hmmm :D
Currently All Trac-less....
Dracov wrote:I'm firmly convinced GT-Four trannies are made from collapsed stars.
TheAutoholic
Postby alltracman78 » Fri Apr 20, 2007 5:42 pm
What?
How do you figure.
You are saying the 3SGTE wiring harness will connect right up to the Camry chassis harnesses?
Unless you have personally done it, or seen it first hand, I really doubt it would.
Re: Old Camry AllTrac with a Heart of Platinum
Postby not12listen » Thu Sep 20, 2007 3:14 pm
TOYRACR92 wrote:Ok well a Friend of mine has finnally finished his
can you do me a huge favor? ask your friend if he used the Camry drive shaft or the Celica drive shaft...
my wife wants to get her AllTrac Camry going. :)
not12listen
Postby GMan » Fri Sep 21, 2007 2:43 am
> alltracman78
> Location: Franklin Ma
> Posted: Wed May 24, 2006 12:45 am Post subject:
He Was using a stock A/A for a time Before he put on the fmic.
> and a huge fmic
The FMIC Could be a fake ? :-)
Just an intake....
All in the eye of the beholder. It is "Only' a Camry.
Bringing on an Old Thread back to life.
Regards;
GMan
Return to Other All Tracs
