89 Camry Alltrac
Camry All Trac, Previa All Trac
89 Camry Alltrac
Postby ESNBuckwild » Tue Dec 30, 2008 5:23 am
Hi to all. I am new to Alltrac.net but not to Toyotas. I own 4 celicas (gen 2-5) I also have a camry alltrac (5 spd). my question is on the transfer case (behind the intake manifold) there is a part with 3 vacuum line ports on it. Does anyone know what that is for and where those lines go. i suspect to those vacuum lines go to theses 2 actuator type things on the drivers side firewall. They have electrical connectors on them and are labeled 1 and 2. can anyone shed some light on this. any help would be great
Postby phattyduck » Fri Jan 09, 2009 9:29 pm
I'm not sure, but that is probably the diff lock system.
'99 4Runner SR5 4WD 5VZ-FE
Postby ESNBuckwild » Sun Jan 11, 2009 6:15 pm
Thanks. Would you happen to have a vacuum diagram on that?
Return to Other All Tracs
