Switch to full style
Camry All Trac, Previa All Trac
Post a reply
jdm 3sgte + toyota camry alltrac 5 speed
Fri May 01, 2009 8:46 pm
i just recently made a purchase of an 800$ MINT 90' toyota camry all trac. im swapping in a jdm 3sgte. my question was is will a 185 tranny bolt roght up or am i gonna be fabbing? otherwise im sticking with the camry tranny
Sat May 09, 2009 2:13 am
If I remember correctly, there is a post or two on here somewhere about doing just this swap. I know I've read about a couple of Camry alltracs that have been 3S swapped. Try searching. I think you'll find them.
Re: jdm 3sgte + toyota camry alltrac 5 speed
Mon May 18, 2009 5:36 am
zero06 wrote:i just recently made a purchase of an 800$ MINT 90' toyota camry all trac. im swapping in a jdm 3sgte. my question was is will a 185 tranny bolt roght up or am i gonna be fabbing? otherwise im sticking with the camry tranny
The camry alltrac manual trans is the same as the early st165 trans. It should all just bolt up including axles.
Mon Jan 28, 2013 12:09 am
I believe mine is all 185
Post a reply
