Switch to full style
Camry All Trac, Previa All Trac
Post a reply
Re: 3SGTE CAMRY UPDATES
Sat Dec 01, 2012 7:48 pm
What a great example of a swapped All-trac Camry. It's what I've always wanted. Can't ever find a clean Camry in Minnesota though.
Tue Dec 11, 2012 6:18 pm
pokemeintheeye wrote:What a great example of a swapped All-trac Camry. It's what I've always wanted. Can't ever find a clean Camry in Minnesota though.
Thank you!! and here is an updade on the cyl head project
Parts for the cylinder head are starting to trickle in!! these will go to the machine shop on Wednesday.
Intake Valve -- TIVN-1012 -- 34.50mm Head Diameter, 5.98mm Stem Diameter, 100.50mm Length
Exhaust Valve -- TEVI-1016 -- 30.00mm Head Diameter, 5.97mm Stem Diameter, 99.50mm Length
The intake valves are made of Stainless Steel with Supertech's Black Nitride Coating applied. The exhaust valves are made of Inconel for their superior heat resistance.
Thu Dec 20, 2012 11:47 pm
The first stage of machine work is done, the valve seats are done and valve guides have been modified for high boost.
these are some photos of the head after an additional cleaning, as you can see the stock 3s-gte intake and exhaust ports are pretty big but will defiantly benefit from some smoothing.
Picked up the head on Tuesday from the machine shop and dropped it off at Outback with John. It will be several weeks before the porting and polishing is done and the rest of the parts come in, although I did get the valve keepers in and the stem seals in yesterday.
Sun Jan 27, 2013 11:57 pm
Hey are you in the northwest WA
I am and I have a 3sgte all Trac camry I just recently picked up
And re assembled it and I just can't find no one but your car
And mine was on here years ago but I'm a new owner
And would like to know a couple things about are 3sgte camry
Mon Jan 28, 2013 6:01 am
yea I live in Bellevue and keep the Camry at my buddy's shop in Auburn.
I would be happy to answer any questions you might have or meet up.
Mon Jan 28, 2013 7:13 pm
Yeah a meet up would be cool
Is there any meets or dyno days going on in are area
Tue Jan 29, 2013 7:37 am
I don't know of anything going on in the near future. Outback Automotive, the shop that I work at part time dose dyno days from time to time. Outback dose mostly Subaru's but it were I built my car and we do a few Toyota's here and there. Also Puget Sound Toyota Owners Club or PSTOC.org holds meets from time to time.
Mon Jul 24, 2017 6:13 pm
Hey I'm new to the forum and I'm gathering info for a swap. How was the wiring for your gte swap? I have an 91 Camry alltrac and I'm trying to decide if I want to got with an st215 gte or an st215 beams... thanks!!
Post a reply
