Camry rear suspension bushings
Camry All Trac, Previa All Trac
Postby New Guy » Thu Dec 29, 2011 9:59 pm
Do all of the bushings from the ST165/185 interchange? My rear end is getting rather loose (240k on stock bushings) and I'd like to fix that at some point.
Thanks,
-Dave the New Guy
Proud owner of an ESV220x.
New Guy
Re: Camry rear suspension bushings
Postby phattyduck » Fri Dec 30, 2011 7:02 pm
Yep, especially if you are talking about just the bushings. SV25/ST165/ST185/ST205 are all compatible in the rear.
(the Camry Alltrac front is like a Camry FWD and different from the Celica, in case you are wondering)
'03 Subaru Impreza WRX Wagon
phattyduck
Postby New Guy » Fri Dec 30, 2011 7:43 pm
I had figured that about the front end! I think I'm gonna go poly up front (AST makes the bushings) because, well, my other DD is a solid-axle Tracker. Ride quality with poly bushings is still going to be amazing, in my book!
Thanks, Charlie! Ya keep pullin' my ass out of the fire, I swear.
Any suggestions on a source for the pillow ball bushings?
Thanks,
-Dave the New Guy
Edit: Never mind about a source for pillow ball bushings- I just saw your post on TN! :notworthy:
New Guy
Return to Other All Tracs
