Nemesis for ST165
General Chat
Would you buy a Nemisis Plug and Play for your ST165
Yes, within one month
1
4%
Yes, within 6 months
5
22%
Yes, within 1 year
5
22%
Yes, at some point
6
26%
No
6
26%
Total votes : 23
Nemesis for ST165
Postby acylon » Wed May 24, 2006 8:31 pm
We are gauging interest to see if it would be worth while to make Hydra Nemesis Plug and Play for the ST165.
Price would be $1795 with wideband.
James Unger
'88 ST175 Rally Car (ENZO)
http://www.pregrid.com/acylon/
acylon
Postby MrWOT » Wed May 24, 2006 9:12 pm
What kind of features can we expect? I've never actually looked into it before since it's gen2+ only. If it's a good system and plug and play, I'd definetly be interested within 6 months.
MrWOT
Postby toytech » Wed May 24, 2006 11:06 pm
I have had one for almost 2 years now, first in my sc now my 165 (same plugs just reassigned the wires) they have always been available if you supply an donor ecu for the connectors. Awsome ems! seems like a good price as well, is there a new source for the connectors?
toytech
Postby nfn15037 » Thu May 25, 2006 3:25 am
toytech wrote: is there a new source for the connectors?
Most any connector is available from AMP distributors with a large enough order.
Thumbs up on the Hydra for AllTracs, it is a very nice EMS!
nfn15037
Postby acylon » Thu Jun 08, 2006 5:29 pm
KO Racing now sells Hydra Nemesis PnP for ST165* and ST185.
Price for ST165 $1895
Price for ST185 $1795
PayPal to Orders@KOracing.net
Features:
Hydra Nemesis Plug & Play Engine Management System
The Hydra product line is powered by dual 16-bit 25MHz Motorola processors which provide fast and accurate control of your engine.
The system has the following features:
Eliminates the stock air flow meter (AFM) and cold start injector
User configurable 32x32 fuel and timing maps with selectable RPM and load points
Two selectable 32x32 fuel and ignition offset maps for alternate fuels
Directly supports the NGK L1H1 and L2H2 5-wire wideband oxygen sensor (additional cable required)
Uses stock engine sensors including the distributor
Built-in launch control (2-step) for drag racing applications (additional cable required)
Controls the stock ignition
Runs full sequential injection
Supports full sequential ignitions
Operates all accessories including AC, power steering, cruise control and ABS
Controls the TVIS, EGR, fuel pump volume and engine check light
Uses the stock idle speed valve to provide a stable idle under different loads
Internal 3-bar MAP sensor supports up to 30psi boost
External MAP sensor support for applications up to 45psi boost (additional sensor required)
Rev limit to 16,000 RPMs with adjustable soft (random miss) and hard (complete cut) rev limiters
RPM adjustable knock detection threshold for detonation protection
Adjustable fuel cut for overboost protection
Easily configurable to work with 91-92, 93-95 and genIII engines
Uses stock narrowband oxygen sensor to maintain proper fuel mixture while idling and cruising
Individual cylinder fuel trims
Quick connect 2-piece laptop cable can be easily routed to passenger cabin
Windows-based tuning software
On-board and laptop datalogging at adjustable timing rates
Controls Aquamist 1S and 2C water injection setups
Adjustable air and coolant temperature correction of fuel and timing
Supports staged injection setups (additional injectors and cable required)
Controls boost (boost control option required)
Operates as a turbo timer (turbo timer option required)
Comes with base maps to start most engine setups and drive them to the dyno for proper power tuning
Controls any level of power from a bone-stock 170rwhp up to +600rwhp monsters
The unit includes:
Hydra Nemesis 2.5 computer
Plug and play adapter for genII and genIII 3S-GTE engines
CD with software and base maps
Cold start MAT sensor plate
Cold start feed plug for stock fuel rail
GM MAT sensor
MAT sensor wire
10' laptop cable (with easy disconnect to thread through firewall to passenger cabin)
4' of 4mm vacuum hose
4mm tee
½" grommet
NTK L1H1 or L2H2 sensor
Wideband sensor to Hydra Nemesis 2 cable
Autotune mode based on target AFR map
Toyota O2 bung to 18Mx1.5 adapter plate
½" grommet
For an additional $150, the unit will include:
Boost control solenoid
Bracket and hardware to attach solenoid to firewall
Boost solenoid to Hydra Nemesis 2.5 cable
For an additional $50, the unit will include:
Turbo timer harness
Turbo timer power relay
For an additional $25, the unit will include:
Launch control cable
*note for ST165 the Nemesis is not 100% perfect pnp because you will need to route the fuel pump switch from the AFM to the Nemesis in order to remove the AFM from the system. Also, if you want to run the injectors in full sequential mode (which I recommend because it makes a little bit more torque and gives you slightly better fuel economy) you will need to rewire two of the injectors.
James Unger
acylon
Postby killer_siller » Sat Jun 10, 2006 2:21 pm
can i get one tomorrow? dead serious. i've got the money. i saw the pricing for an AEM EMS and about cried. this is cheaper wired than that would be in a box. can i get one tomorrow?
killer_siller
Postby acylon » Tue Jun 13, 2006 4:20 pm
Hi Jeff,
The Nemesis can currently be done for a ST165 if you supply an ECU with connectors in good shape – that’s the gating factor. As I understand it, the AEM already is available plug and play for the 165, so I’m not sure why they would need to wire it in. The Nemesis is about $200 less expensive than the AEM, but other than that, they are fairly comparable.
Kris Osheim
KO Racing, Inc.
http://www.koracing.net
acylon
Postby MrWOT » Wed Jun 14, 2006 6:08 am
Happy b-day btw, Acylon :smokes:
MrWOT
Postby acylon » Wed Jun 14, 2006 2:58 pm
MrWOT wrote:Happy b-day btw, Acylon :smokes:
Thanks :D
acylon
Postby acylon » Wed Jun 21, 2006 4:20 pm
OK, after more research into this I have found that AEM does not make a PnP for the ST165.
We now offer the Hydra Nemesis Plug and Play for the Toyota Celica All Trac ST165
Price with Wide band $1895.
For more info go here:
http://alltrac.net/phpBB2/viewtopic.php?p=131490#131490
James Unger
acylon
Postby MrWOT » Wed Jun 21, 2006 4:37 pm
Question time!
#1 How many ignition drivers does the Nemesis support? Will it do coil on plug?
#2 And will it support sequential operation of staged injectors? Do the primary injectors remain on, or can it be configured for secondary fire only at a given rpm, then reintroduce the primary injectors at a second later rpm?
MrWOT
Postby acylon » Wed Jun 21, 2006 7:18 pm
MrWOT wrote:Question time!
The Nemesis has 8 ignition outputs. All outputs are 5 volt low-level fire signals that drive a standard ignitor circuit directly.
The staged injector strategy is hardcoded into the firmware and there is no control over when the primaries and secondaires kick in. You just put how much fuel you want in the map and it brings in the secondaries when it needs to to deliver more fuel.
All this stuff is way beyond plug and play, however.
acylon
Return to Club Chat
