Insanity-74":250rck10 said:I was thinking of adding as resevoir to my system, but just dont have the space....weight might be a small issue but not much. Depending upon where you put it it will need to be a sealed system....you could even put one in the boot. If you can work out a method of doing it, then Id give it either a removable top or a wide filler cap so that if you are doing quater mile runs or short sprint tracks you can fill it with ice cudes and get ubber cool charge air temps.
Awesome, I didn't realize that there was no reservoir but it makes sense now seeing the fill cap is on the chargecooler core. My tuner/mechanic suggested the trunk too, just a lot of lines and water to run I guess. If I were to do that I would put the pump and reservoir in the trunk, but I will try to get a reservoir installed up front first.
Cheers,
Tim
