Transmission Line Help
General Chat
Postby brandontoyota » Mon Aug 17, 2009 5:13 pm
So I have an issue and was wondering if someone on here could help. My Transmission cooler lines rotted out and I'm leakinag a lot of gear oil so I have to take the line out and replace them. I couldnt find it at any AutoZone so I called Toyota. They want $455 for the entire assembly (all the lines, fittings and the cooler itself), does anyone know how else to go about getting the lines for the system? I have a 93' alltrac located in northern New Jersey. I don't know if there are custom shops that will make these lines or if I possibly bypass it somehow or some guy said there is a way to make your own line. Anyone have any input? Thanks, Brandon
my three babies...
1993 Celica All-Trac Widebody st185
1998 Celica GT Caldina Swap st215
2002 Celica GT-S 2zz
www.myspace.com/brandonsuman
brandontoyota
Postby monkey8oi » Mon Aug 17, 2009 5:23 pm
Can you get any pics of the area? I might be able to find those parts in the garage.. Just need to know what i'm looking for.
monkey8oi
Postby brandontoyota » Mon Aug 17, 2009 5:34 pm
monkey8oi wrote:Can you get any pics of the area? I might be able to find those parts in the garage.. Just need to know what i'm looking for.
wow that would be incredible!!!! I'm at work right now but I'll send the pics as soon as I get home, it's the two lines that run out from the bottom of the tranny to a little radiator looking thing, then it just circulates back. But I'll send the pics in a few hours. Thanks for the quick response!
my three babies...
brandontoyota
Postby RedCelicaTRD » Mon Aug 17, 2009 6:07 pm
Do you need the flexable section of the hose or the hardlines right off the cooler?
Wayne
1990 All Trac
2017 SRT Challenger Hellcat
Grumpy Moderator
RedCelicaTRD
Postby Terracar » Mon Aug 17, 2009 7:31 pm
Just a thought - no I have not done it so it might just be crazy but...
Why not get braided line for it?
-Terracar
'92 'trac - Demon - currently in need of some reconstructive surgery.
Terracar
Postby brandontoyota » Mon Aug 17, 2009 9:39 pm
Image[/url]
i need these two lines primarily, they are rotted and just leaking fluid
this line came out from the cooler and it just twisted when i was trying to get the fitting off
please let me know if anyone has a set available. thanks Brandon
my three babies...
brandontoyota
Postby brandontoyota » Mon Aug 17, 2009 9:40 pm
RedCelicaTRD wrote:Do you need the flexable section of the hose or the hardlines right off the cooler?
well the whole line would be awesome, but i guess the flexable section will hold up so mainly just the hard lines right off the cooler. thanks
my three babies...
brandontoyota
Postby BoostedBlueToyotas » Mon Aug 17, 2009 10:23 pm
The hardline(s) are no longer available from toyota. I removed one from
a project alltrac and replaced it with a small metal loop from a mr2 turbo
tranny (think the st165 also used this loop in place of the st185 cooler)
Tim Plessing
Columbia, MD
1990 ST185 - blue/blue cloth 152K-SOLD
1993 MR2 turbo - blue/black leather 59K TOTALLED/PARTING OUT
2006 Acura TSX - black/black 6 spd
2006 Mini Cooper S JCW Space blue/Silver roof 39k
2006 Mini Cooper JCW Silver/black roof 34k
BoostedBlueToyotas
Postby MacGyver » Mon Aug 17, 2009 10:47 pm
+1 for just using braided lines. I would just do a google search for a parker store or simmilar in your area. Usualy any hydrulic hose shop will be able to make you a set. Just take the old ones in and say I want these in steel braided lines. I get them all the time for some machines at work. The shop here by me is called mega fluid lines. Just my 2 cents.
MacGyver
Postby hacker_720 » Wed Aug 19, 2009 3:41 pm
BoostedBlueToyotas wrote:The hardline(s) are no longer available from toyota. I removed one from
Yes, there is just a loop on the 165, but they are not interchangeable, the threads are different. 165 to 185 is different I mean.
BOTTLE ARE FOR BABIES...REAL MEN GET BLOWN
1990 ST185 2.2Lt
hacker_720
Postby grip addict » Wed Aug 19, 2009 3:43 pm
there has to be someone around here that has some left over from a front clip swap or something. having said that, if you can't find them used, do you have o'reilly's out where you are at? some of them make hydraulic lines, and would be able to build you some for not too expensive. if not then maybe pep boys or autozone. if you're having no luck call up a diesel shop and ask them where they get their stuff fixored...
i need to warn everyone-
ATSAaron wrote:You specifically told Matt that "some kid dumped sand into my motor."
don't let some kid dump sand into your motor.
grip addict
Postby Speedricer » Sat Aug 22, 2009 4:25 pm
I ended up making my own lines, I'm looking for the part numbers for the adapters and will post them when I find them.Image
92 ST185 White
3" full exhaust
Megan Racing Springs
FMIC
st215 swap
Speedricer
Images: 8
Re: Transmission Line Help
Postby GT4ZBoy » Wed Oct 07, 2015 3:59 am
Any updates on this? I'm looking for the stock metal lines but they are no longer available. I assume most peeps are just bypassing the metal lines and using custom braided or hoses with the correct fittings?
http://www.xiiimotorsports.com/index.ph ... e-kit.html
GT4ZBoy
Postby quieter » Wed Oct 07, 2015 2:48 pm
wow thats alot of rust
1990 toyota ST185 with st205 goodies (scrapped)
2011 BMW 535xi M pack (daily)
-Simon
quieter
Return to Club Chat
