ST215 Swap Q & A Plus CEL Codes
General Chat
Postby aus jd 2703 » Thu Dec 17, 2009 10:44 pm
can some one tell me if st205 gear box will fit with st185 axles in a st185 or do i need to run st205 axles aswell?
aus jd 2703
Postby Speedricer » Fri Dec 18, 2009 1:41 am
I am 99% sure you can use the 205 gear box with the 185 cv shafts, at least this is what I planned on doing.
92 ST185 White
3" full exhaust
Megan Racing Springs
FMIC
st215 swap
Speedricer
Images: 8
Postby shadowlife25 » Fri Dec 18, 2009 3:22 am
205 gear box will mate up with no issues.
- Mario
shadowlife25
Re: ST215 Swap Q & A Plus CEL Codes
Postby shadowlife25 » Wed Jan 20, 2010 6:57 am
Bump for updates and request for pinout and wiring swap info please! :D
- Mario
shadowlife25
Postby Speedricer » Wed Jan 20, 2010 1:35 pm
92 ST185 White
3" full exhaust
FMIC
st215 swap
Speedricer
Images: 8
Postby shadowlife25 » Wed Jan 20, 2010 9:26 pm
Yes thank you. I had found this also.
I suppose I was more wondering if anyone had their own notes on this.
Something like a pin to pin swap list between say... a 215 and a 165 ecu? ;)
- Mario
shadowlife25
Postby Speedricer » Thu Jan 21, 2010 2:21 am
Here are some of my notes, for a 1992 st185.
These are the two plugs that go from the engine room harness to the body near the ECU.
92 ST185 White
3" full exhaust
FMIC
st215 swap
Speedricer
Images: 8
Postby Speedricer » Thu Jan 21, 2010 2:26 am
I also found some good info. here for both st185 and st165
http://www.gtfour.ca/howtoswap.html
92 ST185 White
3" full exhaust
FMIC
st215 swap
Speedricer
Images: 8
Postby shadowlife25 » Thu Jan 21, 2010 8:33 am
Thanks much. Any information is truly helpful at this point. :)
- Mario
- Mario
shadowlife25
Postby lumbercis » Mon Jan 25, 2010 12:20 am
Could you elaborate on the downpipe? What exactly is the problem with the ST215 item? What modifications are needed? Pics?
So are these the only custom parts needed?
1) Signal converter for the tach
2) Downpipe
Thanks!
J.
Caldina powered...
lumbercis
Postby Speedricer » Mon Jan 25, 2010 12:36 am
The turbo flange is different than the ct26 and older version of the ct20b. This will need to be made or bought, I traced my gasket on some 1/2" stainless steel and used a mill to make it. I also needed to cut apart the downpipe I had and change some of the angles to make it fit my midpipe.
Other than that it is a close swap. I used a lot of the original accessories (starter, power steering pump, transmission, motor mounts).
92 ST185 White
3" full exhaust
FMIC
st215 swap
Speedricer
Images: 8
Postby lumbercis » Sun Mar 07, 2010 8:57 pm
Bump!
What kind of signal converter is needed for this swap? Link? Part number?
Thanks!
Caldina powered...
lumbercis
Postby Speedricer » Mon Mar 08, 2010 9:03 pm
92 ST185 White
3" full exhaust
FMIC
st215 swap
Speedricer
Images: 8
Postby lumbercis » Wed May 19, 2010 12:30 pm
Okay, I have a tech about to undertake this swap for me. He's looking into doing the wiring himself, although I still have the option to send it out to Dr Tweak if he's uncomfortable.
The tech sent me this today: "Do you know what computer is to be used on the new motor? Can you use the computer that came out of the original car. I am thinking the easiest thing to do is to use the original harness and even if I have to use the new computer all I will have to do is put on the ecu plugs."
Besides the idea of using the old ECU :rofl: does it seem like he is on the right track. Or is this a danger sign and I should farm it out to a specialist. I think he wants to do the wiring himself so he doesn't have the car sitting in the shop for 4 weeks while waiting for the harness.
Thanks for your advice.
James
Caldina powered...
lumbercis
Postby MixMaster » Wed May 19, 2010 10:29 pm
Hourly cost of him doing the wiring, then the CHANCE that he get's something wrong is enough to go to tweak.
4 weeks now or countless weeks tracking down a problem, tracing the diagrams, then waiting on it to be fixed. That's if he can even pull it off. You may end up spending $ twice on it.
What's 4 weeks to be positive it's done right by someone with experience when it comes to the jicky wiring.
On a side note: Does the A/C work after this swap? Any CELs?
Good luck
'93 All-Trac Red- JDM swapped
'06 BMW 325i
'08 Chevy Tahoe
MixMaster
Return to Club Chat
