Where is the turbo pressure sensor located on a st185?
General Chat
Postby alltracst185 » Wed May 18, 2011 8:13 pm
I'm in the final stretch with wiring up my AEM EMS and need to find the TPS clip to wire in the MAP sensor. Ithink i know what it is but, would like some asurance. Anyone have a pic of said clip? I zearched with no luck :(
Thanks!
alltracst185
Re: Where is the turbo pressure sensor located on a st185?
Postby Terracar » Wed May 18, 2011 9:23 pm
It is mounted to the fire wall. I will see if I can find a pic. Otherwise I will snap one when I get home since I will be working on trying to get the front strut brace to fit
-Terracar
Terracar
Postby celicasilfee » Wed May 18, 2011 9:47 pm
hey, I know we were both looking for info on where to wire in the MAP & IAT's... apparently you found the info. I have not. Care to share?? :notworthy:
'96 GT (money pit jr)
For show
'90 GT4 RC (money pit sr)
For go
celicasilfee
Postby GT4_ever » Wed May 18, 2011 11:32 pm
Picture borrowed from google and edited! It will have a vacuum line that goes around the left of the intake manifold, and at around the left most point of the intake manifold the line will have a little filter thing on it. Can take better picture if needed!
GT4_ever
Postby alltracst185 » Wed May 18, 2011 11:53 pm
celicasilfee wrote:hey, I know we were both looking for info on where to wire in the MAP & IAT's... apparently you found the info. I have not. Care to share?? :notworthy:
AIT sensor gets wired to the brown and grey/black wire from the AFM, polarity doesn't matter
MAP sensor gets wired to the three wires from the turbo pressure sensor:
AEM Red wire to Pink/Blue OEM harness
AEM Black wire to Brown OEM harness
AEM Green wire to Red/White OEM harness
I plan to do a write-up on this as soon as I'm finished, already have almost all the pics I need :wink:
alltracst185
Postby alltracst185 » Wed May 18, 2011 11:57 pm
I would love a pic of the clip, I really don't want to take the chance of cutting the wrong one off! :doh:
alltracst185
Postby alltracst185 » Thu May 19, 2011 12:26 am
Is this the clip? Seems to have all the right colors and around the stated location :shrug:
alltracst185
Postby Terracar » Thu May 19, 2011 12:40 am
Yes, that appears to be the correct clip. Pic below is of mine:
-Terracar
Terracar
Postby alltracst185 » Thu May 19, 2011 12:52 am
Thanks Terracar! :D
alltracst185
Postby sarnodude » Thu Dec 31, 2015 3:14 am
What does that sensor do ? (the one with the spring-loaded hex knob on it ?)
The reason I am asking is, the one on my car has a hose attached to it that is completely collapsed.
sarnodude
Postby awd3sgte4me » Thu Dec 31, 2015 4:55 pm
That sensor is actually a valve for the a/c. Actually called A/C ASV. Its actuates vacuum for a vacuum switching valve for the A/C.
awd3sgte4me
Postby sarnodude » Thu Dec 31, 2015 5:27 pm
awd3sgte4me wrote:That sensor is actually a valve for the a/c. Actually called A/C ASV. Its actuates vacuum for a vacuum switching valve for the A/C.
That is what I thought, thanks for the clarification, sir! Now if Icould just find a Toyota part number...
sarnodude
Return to Club Chat
