Good day fellow speed junkies.
Okay, so i have a 10x20 storage unit with you guessed it, parts.
DO NOT ASK IF I CAN SELL YOU AN INDIVIDUAL PART, I'M HORRIBLY NOT RELIABLE WITH SHIPPING.
But I do, it'll be in the right section!
I have parts i want to know for people who might be, or wanting to buy an alltrac should be on or off the car when sold. I understand some people just want a solid car. I want zero down time when repairing so i have tons of parts.
What i have new and could install if it would help sell it:
Sibon carbon fiber hood rc edition
Factory unpainted bumper, still factory sealed. With brace.
What i have used
Jdm folding painted to match mirrors(mounted) i also have stock usdm mirrors.
And tons of parts...not your basic...block....
I have two spare engines (gen 2)and trans(185) per car.they have complete long block to turbo and all everything you usually get from an engine supplier to drop in, including a 100% complete fresh rhd harness.
5sfe 96 crank.
One extra good diff, and complete drive shaft front to rear with carrier.
Two water to air units $t205
One complete 165 unit(bad pump)
One 185 rc, with 165 heat exchanger.
Two $t205 ecu
One third gen mr2 ecu
One rc ecu
Two stock California ecu.
Three/four dp catalytic converters
Two mid pipe w/cat
I have a complete set of $t205 brakes front and rear.
Complete 5x114.3 bolt on kit for one car, all brand new parts($800 alone in this). Rotors front and rear and all four hubs.
All the stock suspension prices
And bunches of little parts that aren't stock and are. If you could imagine what a 10x20 full of alltrac parts...then you get the idea. I only listed bigger known parts I've seen. I own two of these cars, and owned 4 so far, I've scrapped one and kept all the parts.
Car has Megan coilovers, white line sway bar and bushings in the rear. Engine is fresh with new mahle pistons and all new oil pump(high volume) water pump...let's just say everything on that side that bolts on to block is new from Toyota. Clutch is exedy 3 puk sprung on stock flywheel. The trans is on a gone through 1995 st205.
Car is sick, i have dumped money, and time. Unlike most people that say they don't have the money to keep their car...always scared me..."What were the last couple repairs like, 'as cheap as you can for as little as you can'" i believed if the car had a problem, fix it and make it better.
When i bought the black car as a dd @77,777 miles, confirmed, with all the vin stickers on the body panels, i bought the car. I dropped 2g into it instant when it got to my shop. Didn't care if it had been done per the original owner or not. I wanted price of mind when driving this black beauty.drive for 1000 before pulling engine to freshen everything up. Owner said a clutch was done....i herd, "done know nothing shop molested an alltrac"
This car has new brakes all around, pads, rotors, brake fluid flushed to dot4. New tires(have 3 sets of the stock rims)
Bottom line, what do YOU want on your alltrac you might buy? and what you would dread? I did all the work at MY shop that works in about 7 other alltracs in my town. I have a bunch of stuff...
#Do i keep it to sell with car or part it out the parts u have.#
I don't need the the money,i want what it's worth though.
What i have used
5sfe 96 crank.
Two $t205 ecu
One rc ecu
Two mid pipe w/cat
