The ST165/ST185/ST205 4WD systems are really FWD? Weigh in!
General Chat
Re: The ST165/ST185/ST205 4WD systems are really FWD? Weigh
Postby athousandleaves » Mon Aug 19, 2013 4:30 am
/thread.
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby Theman88b » Mon Aug 19, 2013 3:31 pm
Thanks for that picture and description^^^^. You guys are forgetting about one thing though...unless you are going 88 mph the flux capacitor will not operate so thus the VC cannot send the proper amount of torque to the wheels.:rofl:
'88 Toyota Celica All Trac Turbo(Blue) 145k - Rebuilt and Bored 1mm over, big psi soon!!
'92 Ford Taurus SHO(White) 212k - Some mods but still my DD
Theman88b
Images: 3
Postby phattyduck » Mon Aug 19, 2013 4:13 pm
It wouldn't be the internet if somebody wasn't spouting off incorrect information. Thank you, athousandleaves for posting the official details from Toyota.
I'll be very curious how good/bad my manual trans Camry Alltrac (no viscous coupler, only the center locker) acts in snow when I finally get it up and running again... The auto-locker on the auto trans Camry Alltrac is kinda fun - slip, slip, lock and go (then oversteer with the helical rear diff I have on it)!
-Charlie
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby CMS-GT4 » Mon Aug 19, 2013 5:51 pm
athousandleaves wrote:
/thread.
LOL, I screen capped the same text but not the image to post in this thread. If he simply took 10 minutes to watch the video he would understand how this actually works and that something is wrong with his gearbox that he is using the base is opinion.
Postby BADNEWS » Thu Nov 21, 2013 12:08 am
Well my car has a stock open front diff. The stock open center diff with an upgraded Mario Viscous Coupling with a rating of 400NM vs the stock Viscous coupling that has a rating of 150-175NM. And a rear Cusco clutch type LSD. Here is a video of me going through and showing my my wheels are linked together.
http://youtu.be/OiVXBazmlWo
Here is a video of me showing the freeplay in the driveline and since I have 2 hands now cause my camera aka my phone is on the ground I have more force to try and move the rear tires through the VC unit fighting me.
http://youtu.be/Xx1f6HNlGQQ
This is a view from the opposite side of the car. I was checking to see that the rear wheels were in fact moving in the same direction which means the center diff/VC unit where moving. If they had moved in opposite directions then that would mean the discs in the rear LSD were allowing the tire to be spun and the Center diff/VC where still stationary.
http://youtu.be/HNkWvblxk6I
90 ST185 W/ HTZ4094R (6768), 2.2, Fully Built
865AWHP, 591 torque
Hope to have some 1/4 times this summer of 2016!!!
BADNEWS
Return to Club Chat
