Well-known member
I just got the front & rear suspension bushings pressed out & new ones pressed in, it ended up taking the shop somewhere around 6 hours & therefore got fairly expensive. I've still got the rear subframe bushings to do, as well as all the suspension bushings for my GTS, so I'm thinking of learning to do it myself.
Would something like this do the trick? http://www.princessauto.com/pal/product ... -Top-Press
Do I need anything else to press the bushings out/in? Any tips on how to go about this?
