How long since you have driven your alltrac?
General Chat
Re: How long since you have driven your alltrac?
Postby awdkid44 » Sat Jan 11, 2014 6:08 am
Over a year, and i miss it so much! last december i spun the number 2 bearing and now i am doing a full build, so its gonna be even longer till i could get in and smoke a civic.
serious1
awdkid44
Postby Mr Alltrac » Sun Jan 19, 2014 4:11 am
Finally replaced my front wheel hub and shifter cables( what a pita) drove it today for the first time in awhile. Felt good, glad I got it running again
Mr Alltrac
Postby ktulu » Sun Jan 19, 2014 5:33 am
I haven't gotten to drive mine yet. Picked it up thinking it'd be a simple timing belt install. Nope intake cam wouldn't move, took the head off and took it to a shop thinking it was bent valves. Turns out the valves were just stuck from sitting. Still waiting to get the head back and everything put back on. Then I have to tackle the brake lines, luckily the guy I bought it from had replace half of them, so only half are bad.
Indiana
1988 celica alltrac 82k original miles
ktulu
Postby psipwrd » Sun Jan 19, 2014 9:38 am
Skimming through is half depressing!
Feb 2013, hopefully will drive before Feb 2014.
psipwrd
Postby ALLensTRAC » Mon Jan 20, 2014 1:35 pm
4 year anniversary today since I've driven mine. I have a feeling my 3 year old will be driving by the time it's done ugh!!!!
Allen
ALLensTRAC
Postby ishmael.7 » Tue Jan 21, 2014 8:33 pm
I agree reading some of these posts are depressing :cry: My all trac still needs some more preventative maintenance done to it before I feel better. I want to change out my radiator and do a coolant flush, and flush all tranny and rear diff fluids as well as port and polish my head. Then I will be happy driving it knowing it should not break hahaha.
ishmael.7
Postby cgtdream » Tue Jan 21, 2014 9:53 pm
Well i dont drive an alltrac but i do own a 205. Been sitting in japan about 500ft from a seawall on a small island since December 2010. Last time i saw it in person was a few months ago and whilst the body was "ok" (was under a car cover thank god) the obvious things were rusted to shit. Including the motor. Going to shell out some saved my just to get things back in working order come mid this year. This is how she currently sits, with car cover on of course....
cgtdream
Postby pero » Thu Jan 23, 2014 6:36 pm
Last week, but I only ended up goin around the block due to a fuel line leak under car.
Probably fix it next week and replace brake pads and rotors while I'm at it.
1990 ST185 - mostly stock
2002 IS300 5-speed manual - not so stock
pero
Postby Terracar » Fri Jan 24, 2014 2:49 pm
If you define "driven" as driving it legally licensed and on an actual road, then December 23, 2011. Otherwise I drove it around on the property about 3 months ago.
-Terracar
Terracar
Postby Bartmuley » Mon Feb 03, 2014 12:12 am
I drive mine everyday.
Bartmuley
Return to Club Chat
