Simple question 3sge and 3sgte
General Chat
Postby UtahSleeper » Wed Feb 27, 2013 5:35 pm
So, simple question to make sure I remember this right.
Both 1st gen 3sge and 3sgte are the same motor, minus the cams and valve covers correct? Asking cause I may be able to score a cheap 3sge
UtahSleeper
Re: Simple question 3sge and 3sgte
Postby brutekiller787 » Fri Mar 01, 2013 1:51 am
in essense yes. more than cams and valvecovers though. intake manifold (ge is better), pistons, oil squirters are the main differences. i'm sure something about the oil and cooling systems are different too as they have to go to the turbo in the gte
brutekiller787
Postby 88gt4DE » Fri Mar 01, 2013 1:57 am
Blocks are different to support oil cooler in front of engine under turbo ...
Postby Mafix » Fri Mar 01, 2013 7:02 pm
oil cooler/cylinder head (all but the combustion chamber)/oil squirters/compression ratio.
that said 90% of the stuff will work
Postby UtahSleeper » Fri Mar 22, 2013 12:59 am
So, some questions for the knowledgable.
Here is the 3sge I got for trade recently. Outside is clean. Story is that one of the PO's bought it in the 90's and it sat since then. The PO also said the had swapped out the head for the turbo head. Not sure on any of this. How would one tell if it had the turbo head or stock? Or was the only difference cams?
Here is the intake valves.
The closed whole here, could that be used for a knock sensor or is it too low? Where would you mount one?
On a 3sge, what would need to be changed to make it suitable for turbo? Looking to make it useable as a winter fun car with minimal power gains. Probably stock ish build, but ran by a MS. I plan on opening the motor soon and seeing what I have, but trying to also research my options.
Thanks.
UtahSleeper
Postby underscore » Fri Mar 22, 2013 1:06 am
I'm not positive, but that may be an MR2 valve cover.
Postby Rpz123isme » Fri Mar 22, 2013 3:39 am
The path for fuel is not the same. The gte uses a y shaped path. The block needs milled to fit the trans. Its not plasable to do oil squirters, no banjo for turbo oil feed, but if you use a ge let me know if you need help i have a ge block and head in my trac with hyperutectic ge pistons, a custome made crank running low 11s on pump gas. I call it a 4sgte (:. Best part is the ge head does not stress crack! And the ge cams with tight clearance is super close to the same diration at .050 as the hks cams its not even funny. Just need .002 taken fron the bottom of the lobe to get a nice lift.
Hesperia, CA
Rpz123isme
Postby UtahSleeper » Fri Mar 22, 2013 4:06 am
I am considering using the ge block I have in the pic, or just rebuilding the motor in the car. Either way, its work.
Would the third pic be good for a knock sensor? How much needs to be milled? Would the stock pistons be ok to use, or am I better off getting other pistons?
It was your build rpz that made me decide to pick up the motor for use, just need to see how much work I need to do to try and use it. Trying to keep budget down though so I can realistically have it running before summer ends, and the car still needs other things done lol.
UtahSleeper
Postby Rpz123isme » Fri Mar 22, 2013 4:25 am
Ok the ge and gte pistons, rods, and bearings are the same, the 3sfe block casting is the same as the gte, just with out machine work done. The ge head is the same minus one water bridge and Y shaped injector path. With minor port work and some research the ge motor will make gte power. Just text me if you have questions. Ill pm u my number!
Hesperia, CA
Rpz123isme
Postby UtahSleeper » Mon Apr 08, 2013 4:40 pm
So, when you take apart an engine is it no questions asked that you replace all bearings? A motor I am starting to pull apart has rust on the crank and little places, so I will be taking the whole thing apart, cleaning and such.......as soon as I learn what all will be needed to fill the such role lol. This is all new shit for me.
UtahSleeper
Postby UtahSleeper » Wed Apr 24, 2013 4:26 pm
Bump.
Also, how do you remove the rear main seal/holder thing? I removed all the bolts, but cant get it past the end of the crank. The seal seems to be stopping me.
UtahSleeper
Postby Awesome-Trac » Sun Aug 16, 2015 5:32 am
I know this is a old thread but does anyone know if the 3sge and a 1st gen 3sgte thermostat are the same?
•Daniel
Awesome-Trac
Postby UtahSleeper » Sun Aug 16, 2015 5:59 am
I dont know for sure, but I would guess yes cause the block is the same.
UtahSleeper
Return to Club Chat
