4 PSI boost :( limp mode??
General Chat
Postby st165fan » Thu Jul 11, 2013 5:45 pm
Hey guys so this is freshly rebuilt engine and i havent been able to make over 4 psi... before rebuild it was 12-15ish. i have a MBC and one side of my wastegate actuator is capped. ive been looking through tonnes of other posts but cant find any that apply. is this some sort of limp mode?? i can take pictures of anything you may need or relay info. please help me! no one knows our engines like we do!
st165fan
Re: 4 PSI boost :( limp mode??
Postby underscore » Fri Jul 12, 2013 2:37 am
When my RC was in limp mode it was capped at 4psi, I'd assume this is the same for all of them.
Postby st165fan » Fri Jul 12, 2013 3:40 pm
why was your in limp mode? im out of ideas as to what has occured. the PO did alot of cheap mods so im slowly weeding them out but right now im stumped :(
st165fan
Postby underscore » Sat Jul 13, 2013 2:38 am
My WTA level float was bad, resulting in a CEL and limp mode.
Still beat a supercharged B18 Civic running 10psi though...
Postby Theman88b » Thu Sep 19, 2013 12:02 am
I know it has been a while but did you figure out the issue? If you are running a manual boost controller straight from the wastegate actuator to the compressor then the limp mode should not apply, at least limp boost, timing may still be a factor. Basically you have bypassed the switching valve that opens the wastegate early due to limp mode.
'88 Toyota Celica All-Trac Turbo(Blue) 145k - Race car!!!
'92 Ford Taurus SHO(White) 212k - Intake and exhaust, needs a clutch at the moment
'98 Jeep Cherokee - Current DD, 33" tires and 2 light bars :rofl:
Theman88b
Images: 3
Postby underscore » Sun Sep 22, 2013 4:12 pm
The TVSV can only drop it to 7psi in 3/4/5 by deciding not to bleed off pressure, that's it as far as I know, I'm not sure how it drops to 4psi.
Postby zblu81 » Sat Oct 19, 2013 12:00 pm
I belive if you bypass your MBC by running a hose directly from the compressor to the wastegate you should get wastegate pressure, Around 7-8 PSI. If that works there could be wrong with your MBC maybe? although I don't know how a MBC could actually reduce boost pressure.
Or I think if you capped both the wastegate port and the compressor port your boost would only be limited by what the turbo is capable of (and maybe fuel cut)
[b][/b]Greg
Lansing, MI
'92 turbo All-Trac
3" Exhaust, RC intercooler, ATS TD06-20g, stage2 clutch
zblu81
Postby underscore » Sat Oct 19, 2013 3:12 pm
I think it uses other method to reduce the boost to 4psi, as the TVSV can only increase boost.
Postby zblu81 » Sat Oct 19, 2013 7:19 pm
Could be. I was just making suggestions of things he could try to see if the MBC is working.
[b][/b]Greg
Lansing, MI
'92 turbo All-Trac
zblu81
Return to Club Chat
Users browsing this forum: Google [Bot] and 3 guests
