Steering wheel suggestions
General Chat
Re: Steering wheel suggestions
Postby FC Zach » Fri Apr 14, 2017 7:10 am
You'll lose the airbag, no way around it. You'll also loose the cruise control unless you find a way to secure it to the hub.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby Il_Barone » Fri Apr 14, 2017 10:57 am
FC Zach wrote:You'll lose the airbag, no way around it. You'll also loose the cruise control unless you find a way to secure it to the hub.
Ok, thank you.
Last question: i'll have no problems with the electrical? (error codes ecc..)
Thank you :)
Il_Barone
Postby mx6er2587 » Sat Apr 15, 2017 2:02 am
I believe if you disconnect the airbag ECU and Cruise controller you shouldn't see any warning lights. Can someone else confirm?
mx6er2587
Return to Club Chat
