An All-Trac Legacy
General Chat
Re: An All-Trac Legacy
Postby jwgt41 » Mon Jan 09, 2017 10:35 pm
Putting it that way doesn't make it sound any better
1990 Toyota Celica All-Trac
2001 Toyota Solara
2003 Subaru WRX
2005 Toyota Tundra
2011 BMW 335iX
jwgt41
Postby underscore » Mon Jan 09, 2017 10:47 pm
True, I'm just not sure if you're lucky or crazy. Or maybe both?
Postby jwgt41 » Tue Jan 10, 2017 2:10 am
Fair enough to say a little of both. But I certainly paid for it at the time.
Engine build time! You know it's been awhile based simply on the quality of the photos. I sent the block and head to the machine shop for the usual. The block was overbored to 86.5mm and the head had the seats reground, ported and polished. Based on Fraser's recommendations, I did not change valves or valve springs. My power goals did not require it. I also asked that the head not be reassembled so that I could check the work myself. It's a good thing I did because the cams were installed in the wrong positions. Enjoy some engine goodness!
Ground down the main bearing saddle supports, both to promote oil drainage and to strengthen crucial stress areas.
2001 Toyota Solara
2003 Subaru WRX
2005 Toyota Tundra
2011 BMW 335iX
jwgt41
Return to Club Chat
