Where to buy a new alternator?
General Chat
Postby Spectra1 » Wed Dec 18, 2013 3:33 am
The bearings are going in my alternator so I think it is time for a new one. A few years ago I picked one up for my other alltrac on ebay and so far it has worked great, problem is I cant remember who I got it from. Can anyone recommend a seller or brand. I dont want to spend a fortune so im not looking for an oem unit.
93 St185 DD
90 ST185 - Project
Spectra1
Re: Where to buy a new alternator?
Postby knowitalls » Wed Dec 18, 2013 4:48 am
I got mine from Autozone. Had to modify the plug part very slightly.
If you didn't build it, it ain't yours.
knowitalls
Postby warracer » Wed Dec 18, 2013 5:30 am
got mine rebuilt at a local shop, did an okay job but didn't replace the voltage regulator :/
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby RallyX-GT4 » Wed Dec 18, 2013 5:56 am
Got mine from the local dealership - I was amazed how reasonable it was. Although not a brand new unit, it is remanufactured to their spec. Completely plug and play and has worked perfectly!
1988 - ST165 - RallyCross #3
RallyX-GT4
Postby Spectra1 » Wed Dec 18, 2013 3:27 pm
Are all 1990-93 Celica alternators the same (ST, GT, GTS, Alltrac, 2.0, 2.2, etc) other than the amperage? Im looking at a 92 2.2L one from Ace alternators.
93 St185 DD
90 ST185 - Project
Spectra1
Postby knowitalls » Wed Dec 18, 2013 11:43 pm
Spectra1 wrote:Are all 1990-93 Celica alternators the same (ST, GT, GTS, Alltrac, 2.0, 2.2, etc) other than the amperage? Im looking at a 92 2.2L one from Ace alternators.
No
knowitalls
Postby Spectra1 » Sat Dec 21, 2013 3:10 am
Ok are the 2.0L 3sgte MR2 alternators the same as the all trac?
93 St185 DD
90 ST185 - Project
Spectra1
Postby warracer » Sat Dec 21, 2013 4:49 am
Spectra1 wrote:Ok are the 2.0L 3sgte MR2 alternators the same as the all trac?
No, the bracket is different, so you would have to put the alternator behind the engine , but it can be done...
Pulley is also different
____________
ST185H A-Spec:
warracer
Postby underscore » Fri Jun 13, 2014 2:30 am
No
What's the difference between them aside from the wire placement and the metal shroud? I think my RC alternator has pooped out but I have a brand new Bosch reman GTS alternator sitting here.
Postby warracer » Fri Jun 13, 2014 2:32 am
The pulley is different, one is 5rib, other is 4.
____________
ST185H A-Spec:
warracer
Postby Nitro_Alltrac » Sun Jun 15, 2014 5:39 pm
I've got one for a GT-S on mine. It was a straight bolt on. Didn't have to change the pulley or do anything with the plug. I got it from O'Reilly's. I special ordered the one specific for the All Trac first and had issues with it a couple of weeks later and HAD to have a replacement. I think I used the one for the auto GT-S as it had a higher output. I've had it on there for four years now and no problems.
Mike
92 All Trac - Daily Driver
Nitro_Alltrac
Postby underscore » Mon Jun 16, 2014 9:18 pm
I compared the GTS one I had and the one in the RC and the RC uses a three pin plug and the GTS had a totally different plug. I tried swapping the guts but I think the reg itself is fried.
Postby Nitro_Alltrac » Mon Jun 16, 2014 10:01 pm
My car is a NA All Trac so there maybe a difference there. My engine is a JDM unit but the car has the US harness.
Mike
Nitro_Alltrac
Return to Club Chat
