Front wheel bearing replacement options?
General Chat
Postby Spectra1 » Wed Dec 18, 2013 7:56 pm
Needing some new front wheel bearings. Was looking for NSK bearings but I can only find the rear. Can anyone recommend a good aftermarket front wheel bearing and place to buy them? If there is no good aftermarket wheel bearings can anyone recommend a good online source for OEM?
93 St185 DD
90 ST185 - Project
Spectra1
Re: Front wheel bearing replacement options?
Postby JohnNK » Wed Dec 18, 2013 8:28 pm
These guys are great for OEM: [http://www.lithiatoyotaparts.com]
JohnNK
Postby Spectra1 » Wed Dec 18, 2013 8:35 pm
Thanks ill check them out.
93 St185 DD
90 ST185 - Project
Spectra1
Postby 88gt4DE » Sun Dec 22, 2013 3:04 am
I just used autozones ... against my will because it was in a pinch but they actually fit well and are quiet ...
Postby Awesome-Trac » Sun Dec 22, 2013 6:44 am
88 Camry works as well, I got it from napa auto and it worked great btw how long have you been driving on that bearing?
•Daniel
Awesome-Trac
Postby CTechBlueDragon » Sun Dec 22, 2013 10:35 am
If you have driven around on an already noticeably bad bearing chances are one or both of your front hubs have been ruined as well. Be prepared to wait if you get it all apart and need a hub because none of the normal part places have them. I found them for about 140 a piece new. Your cheapest option is a used one ofcource, any 90-93 celica 5 stud hub will work.
CTechBlueDragon
Images: 51
Postby Spectra1 » Mon Dec 23, 2013 3:56 am
CTechBlueDragon wrote:If you have driven around on an already noticeably bad bearing chances are one or both of your front hubs have been ruined as well. Be prepared to wait if you get it all apart and need a hub because none of the normal part places have them. I found them for about 140 a piece new. Your cheapest option is a used one ofcource, any 90-93 celica 5 stud hub will work.
Ya thats what I was afraid of. So if all hubs are the same then are all wheel bearings the same (GT,GTS, ST, Alltrac)? I have a set of 1990 Celica ST hubs back home that I could have sent to me, would they be compatible?
93 St185 DD
90 ST185 - Project
Spectra1
Postby mx6er2587 » Mon Dec 23, 2013 12:00 pm
all the 5 bolt front hubs are the same. Some(all?) of the STs use a 4 bolt hub
mx6er2587
Postby CTechBlueDragon » Mon Dec 23, 2013 2:40 pm
mx6er2587 wrote:all the 5 bolt front hubs are the same. Some(all?) of the STs use a 4 bolt hub
what he said
If your going to have someone send them you will need to have the hub pressed out of the knuckle housing or the shipping will be insane.
CTechBlueDragon
Images: 51
Postby Spectra1 » Tue Dec 24, 2013 1:25 am
so when you guys say hub what exactly do you mean? does any one have a pic of just the hub?
93 St185 DD
90 ST185 - Project
Spectra1
Postby BoostedBlueToyotas » Tue Dec 24, 2013 2:01 am
The hub is part that has studs (bolts) that you put wheel on. The knuckle or carrier is part that
struts and other suspension pieces bolt to :)
Tim Plessing
Columbia, MD
BoostedBlueToyotas
Postby Meenya » Wed Dec 25, 2013 3:20 am
Turbo4wd/Alltrac/GTFour use same part (bearing) for front and rear wheels which usually is not a case. I'm not sure about FWD models.
I have always bought from these guys 1stToyotaParts.com but there are others out there.
Mike
93 Turbo 4WD
91 GTFour RC
07 R6
Meenya
Images: 19
Return to Club Chat
