Is loose feel while shifting normal?
General Chat
Postby Bartmuley » Sun Feb 02, 2014 11:58 pm
I have a 1990 Alltrac, approx 75,000 miles. It has really long throws and feels loose when shifting. Especially when compared to my MR2 Spyder.
Basically just wondering if these cars are normally like that?
Bartmuley
Re: Is loose feel while shifting normal?
Postby warracer » Mon Feb 03, 2014 1:37 am
long trow, yes
loose, no
broken shifter bushing or damaged shifter cable maybe an issue
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby underscore » Mon Feb 03, 2014 1:56 am
my GTS feels extremely loose but it shifts gears just fine. Have a look at the "sugar cube" near the tranny end of the shift cables, apparently that can wear down quite a bit and rotating it tightens things up again.
Postby Bartmuley » Mon Feb 03, 2014 4:20 am
underscore wrote:my GTS feels extremely loose but it shifts gears just fine. Have a look at the "sugar cube" near the tranny end of the shift cables, apparently that can wear down quite a bit and rotating it tightens things up again.
It shifts fine. It's just has the most play of any car I've driven. Thanks for the replies.
Bartmuley
Return to Club Chat
