ST185 Wilwood 6-piston front brake kit
General Chat
Postby dragstang86 » Sun Feb 16, 2014 6:27 pm
Would there be any interest in bringing back the 6-piston WIlwood front brake kits like what Rocketeer used to sell? I have one of the Rocketeer kits on my car and also have ties to WIlwood and have thought about looking into reproducing it if there is any interest.
92 All trac
dragstang86
Re: ST185 Wilwood 6-piston front brake kit
Postby C-dubb » Sun Feb 16, 2014 7:11 pm
yes
Cory Wilson 1990 st185
C-dubb
Postby toayoztan » Sun Feb 16, 2014 11:42 pm
Yes!
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby psipwrd » Mon Feb 17, 2014 8:45 am
The problem with Wilwood for me is the area circled in red, but CEIKA's clear my wheels with a few mm to spare.
CEIKA tried to sell me way more brake than I asked for. Once I free up some funds, I'll be looking to get the CEIKAs, otherwise, I'd have the wilwood 4pots by now.
psipwrd
Postby YerRandO » Mon Feb 17, 2014 5:46 pm
With two piece rotors? Yes please
-James
YerRandO
Postby celicamonkey » Mon Feb 17, 2014 6:20 pm
Yes
Dustin
2008 Legacy GT
1990 Celica All-Trac
1990 Celica GT
celicamonkey
Postby aus jd 2703 » Mon Feb 17, 2014 8:54 pm
let me start by saying I have the revolution kit and had 205 callipers before going the wilwood route as I didn't like the necessary modification's to run the 205 brakes.
ive done a few track days with hard sessions. I do run ducting to help and the revolution kit appears to be adequate, have temp stickers on the calipers and it never got the caliper temps over 150'c. I run ferrodo ds3000 pads and the bite is awesome and zero fade as expected they get better towards the end of the run....
from my experiences:
unless our going to run the W6A caliper or the TC6 ie the big pad calipers, there is no advantage to running the 6 over 4 piston wilwoods as the pads are the same size and the 4 are already verging on two much piston area. (long pedal travel).
if you want the 6 piston cool factor go nuts but performance wise the gains are minimal and its possibly worse depending on piston diameter selection.
oh and as for the differential piston bores I have no noticeable pad taper....
imo revolution kit, good pads and fluid and ull be fine for 90% of competition. and the 10% you wont have enough brakes for you would need a large budget so the AP kit would be the ideal option.
aus jd 2703
Postby ishmael.7 » Mon Feb 17, 2014 10:06 pm
How much would it cost.
ishmael.7
Return to Club Chat
