help!!! newbie question here
General Chat
Postby AWDtime » Sun Aug 31, 2014 6:22 pm
OK I new to the Alltrac and was wounding if a greddy tdo6 turbo for a mr2 will bolt straight up to the stock st185 manifold and downpipe ??..thanks
AWDtime
Re: help!!! newbie question here
Postby WarTowels » Sun Aug 31, 2014 9:46 pm
Depends what "for a mr2" means.
Basically any turbo will require some sort of adapter. If that adapter is included because it was on an Mr2, then yes. Otherwise, no.
It will NOT bolt up to a stock downpipe.
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby AWDtime » Mon Sep 01, 2014 12:56 am
Ya the kit does come with a manifold adapter for the mr2, so with that it should just bolt right up to the Alltrac manifold right? so all I would need is a aftermarket downpipe right?..thanks
AWDtime
Postby WarTowels » Sat Sep 06, 2014 1:13 am
Yes, if you have the adapter it should bolt right up.
Greddy has a downpipe for the TD06 20g that is a stock replacement i.e. bolts to the stock exhaust. You may be able to source somewhere... but I have no idea where.
You can't just use "an aftermarket" downpipe, per say, as those have the flange for the CT26 turbo. I don't have a good pic, but here is a wrapped one for the td06: Image
GL!
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby WarTowels » Sat Sep 06, 2014 1:14 am
Turns out ATS makes a replacement: http://www.atsracing.net/Parts/Details/EX-ATS-DP-TD06
Cheers
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby AWDtime » Sun Sep 07, 2014 3:10 pm
Thanks!!! That answers my question
AWDtime
Return to Club Chat
