ST185 Charcoal Canister Toyota Code
General Chat
Postby Il_Barone » Tue Jan 20, 2015 3:05 pm
Hi!
I have to change my charcoal canister, but the Toyota dealer of my city can not find the code of the original replacement.
Can you help me?
I also watched on toyotamarket.ru but there's only the EGR picture. Not the canister.
It's a 1991 St185 All Trac.
Thanks for your help.
Daniele
Il_Barone
Re: ST185 Charcoal Canister Toyota Code
Postby yyonline » Wed Jan 21, 2015 3:39 pm
The charcoal canister is Toyota part number 77704-20270:
http://toyotamarket.ru/eu/252560/019/3/7701/2/77740/
Unfortunately, it has been discontinued and is no longer available for purchase (at least in the US, not sure if availability is different internationally - I'm assuming Genova is in Italy?). The good news is that it should be fairly easy to find a used replacement part, as all 90-93 Celicas use the same canister, even the 2wd Celicas (at least in the US, not as familiar with EU Celicas).
If you have a copy of the service manual, there's a few quick and easy tests you can do to check whether your current canister is clogged, and you can clean out the internal filter with compressed air. However, if the canister is clogged with fuel, you'll likely need a replacement.
See page EC-19 to EC-21:
http://discodan.org/gfx/celica/servicem ... ine/ec.pdf
yyonline
Postby alltracman78 » Wed Jan 21, 2015 10:37 pm
Japanese cars used a different [smaller] canister than US cars.
They also used a slightly different system for the EVAP.
A picture of your canister/setup might help.
Postby Il_Barone » Thu Jan 22, 2015 3:47 pm
Thanks for your help!
I was looking it in the "engine" pictures, not in the tank one :D :D
A new Canister (it's still available) costs 190€ (about 200$ more or less) :shock: :shock: :shock: :shock:
I think i'll look for an used one :D
Il_Barone
Postby Il_Barone » Thu Jan 22, 2015 3:48 pm
yyonline wrote:I'm assuming Genova is in Italy?
Exactly :D
Il_Barone
Postby Il_Barone » Thu Jan 22, 2015 8:01 pm
Me again.
The code is 7775120270, i guess. You can see here http://toyotamarket.ru/us/252460/019/3/7701/2/77751/
I have the rubber hose broken. It cross the canister base but i don't know if it's sold with the base (7775120270) or if i have to buy it separately. In the second case, i can't find it in the pictures :shrug: :cry: :cry:
Here there're some pics of the base and the hose.
Thanks.
Daniele
Il_Barone
Postby yyonline » Thu Jan 22, 2015 8:27 pm
The same thing happened to me when I replaced the charcoal canister on my Celica ST a few years ago. That hose is part of the canister base 77751; it's not available separately. USA and EU cars use the same charcoal canister base, which is no longer available from Toyota. So you'll have to find a used one from another 90-93 Celica.
Correction to original post, as it wasn't very clear: The hose is part of the canister base (7775120270). But that part has been discontinued by Toyota.
yyonline
Postby Il_Barone » Fri Jan 23, 2015 9:58 am
I'll go on monday to the Toyota spare dealer
Il_Barone
Postby yyonline » Fri Mar 13, 2015 6:50 am
If you still need this hose, I recently found one off a junked car. The hose is in good shape though. Shipping to Italy might be a bit pricey, but if you can't find one there it might be worth it. If you still need it, send me a message and we can work something out.
yyonline
Postby Il_Barone » Fri Mar 13, 2015 1:20 pm
yyonline wrote:If you still need this hose, I recently found one off a junked car. The hose is in good shape though. Shipping to Italy might be a bit pricey, but if you can't find one there it might be worth it. If you still need it, send me a message and we can work something out.
Ok i'll send you a pm!
Il_Barone
Return to Club Chat
