Kurt_st185_gt4
New member
I may have discovered something here guys. I was in the same pursuit as psipwrd in that I need an ABS sensor to pass inspection. What I have discovered is that the sensor is interchangeable left to right. Both front sensors share the same connector and vice versa for the rear. The only difference is they bolt up backwards so to speak but that should be an easy hardware swap fix. Or if dealing with the rear sensors you shouldn't have to swap anything as they do not have the long bracket on the wire. My idea is to mark the wires, disconnect the prongs from the connector, slide out of "wrong" bracket and into the correct one, reinstall pins to the connector using the markings made earlier and voila! However this is assuming you can locate a abs sensor at all. To which I'm buying a t18 gti(euro version gt/gts) as a parts car and will use its sensor and hub to replace mine. Lots of celicas (relatively speaking) in germany. Let me know if you guys need any parts that can be found in the other 5th gens. I'll check out the local scrap yard and german sites.
