TVIS... to pull or not to pull
General Chat
TVIS
Remove
8
38%
Keep on
13
62%
Total votes : 21
Postby omgitsroy326 » Sun Oct 16, 2005 8:31 pm
Should I remove it ?
I'm gettin my head redone by ths one shop... What exactly do i need to take off... is it just the butterfly part?? anyone got pictures???
BraveUlysses had said that it's beend dyno proven to inscrease low end torque
omgitsroy326
Postby CMS-GT4 » Sun Oct 16, 2005 9:27 pm
If your power goal is only 350 or so, I would keep it. It has been proven to be of benifit if you control it. There is a thread on this around here somewhere.
Postby BoostedBlueToyotas » Sun Oct 16, 2005 9:43 pm
Removing the TVIS unit would cost you torque down low
Controlling the opening point (if I remember right its at 3800 vs
the 4200 rpm stock opening point) actually improves on the stock setup
You would want to gut the unit (or buy a Manj phenolic spacer at $225)
so you keep the stock TB (and TB stay) geometry
Unless you are making a pile of power (and then you would probably
get an aftermarket intake manifold anyways) I would keep the unit. My 2 cents
Tim Plessing
Columbia, MD
BoostedBlueToyotas
Postby Zeus » Mon Oct 17, 2005 5:17 am
yeah post your goals so we know what to vote for ;)
Blake Brown
Zeus
Postby omgitsroy326 » Mon Oct 17, 2005 5:41 am
i wanna go to whatever stock internals can take me w/ a new metal head gasket... what would that be around?
omgitsroy326
Postby Zeus » Mon Oct 17, 2005 7:06 am
reliably? ;)
Blake Brown
Zeus
Postby omgitsroy326 » Mon Oct 17, 2005 11:02 am
yes reliable :D
omgitsroy326
Postby QIK_GT4 » Mon Oct 17, 2005 1:47 pm
just wondering does my st185 have tvis? it dosent seem to be there :shrug:
The Car:Black JDM 1990 ST185
The Mods: Whiteline Rear-sway-bar, K&N Panel, 3" Dump, HKS BOV, 2" Boost Gauge, Garret TMIC, TWM Short Shifter, Mirror Tints
QIK_GT4
Postby C-dubb » Mon Oct 17, 2005 8:01 pm
omgitsroy326 wrote:i wanna go to whatever stock internals can take me w/ a new metal head gasket... what would that be around?
with that said i would keep the tvis and controll it. i'm not sure what kind of power you can make on stock internals with reliability in mind...? I would think they could hold a good 17psi...i have heard of some MR2 owners running 20psi on stock internals.
Cory Wilson 1990 st185
C-dubb
Postby muneo » Tue Oct 18, 2005 6:33 pm
I remember seeing a good article on this using the 4age? motor. I forgot the exact motor but another toyota motor was dynoed with and without the TVIS system. the results showed that ona stock motor, the system is quite helpful. Anyone remember the site or link to this?
muneo
Postby saved_1992 » Tue Oct 18, 2005 7:01 pm
just remove the butterflys, if you are going to be running higher than stock boost there will put more strain on the butterfly screws. plus if the butterflys come off say hello to alot of internal noise and possible damage to valves,cyld. walls and pistons.
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby ___Scott___ » Tue Oct 18, 2005 9:29 pm
Actually you don't notice any strange noises, just an immediate loss of power. The cylinders survive quite well, but the head and pistons get thoroughly trashed. Valves and seats require a re-grind at a minimum.
I say keep the butterfly plates, but center-punch the screws on the end that comes through the shaft so that the end of the screw is flared slightly and can't back out.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby ruffneck » Wed Oct 19, 2005 6:00 am
On the ones that I have seen, this is already done from factory? I am going with a gutted plate on my new engine, if you drive it with the vac line pulled so the tvis is always open you will find a little loss, but not a huge deal....and in my experience I don't get much out of my 3sgte/ct27 below 3100 rpm. It's recommended to open it at 36/3700 rpm, so big deal, lose 500 rpm.. I say gut the tvis and KeepItSimple/Safe.
ruffneck
st185 that's getting there
melb, aust.
ruffneck
Postby gearhead313 » Sun Oct 23, 2005 9:51 pm
start hogging that b*tch out...
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Postby 935motorsports » Sun Oct 23, 2005 10:09 pm
It depends on how much you drive your car.
I used to drive my ST185 quite a bit, stop and go stop and go. I always thought my car was fairly zippy, coming from ST165 land.
However, when I changed my clutch I noticed that the TVIS was actually not hooked up!
After I hooked it up and going for the same drives day to day, it was 10x better! I had insta torque for the low end and loved every minute of it.
So from a daily driver aspect, keep it. However, after you up the boost, get exhaust, etc. you will find that it does not open early enough anymore. An rpm controller would be nice, but otherwise just leave it disabled.
935motorsports
Return to Club Chat
