Supercharged 1mzfe alltrac-would you do it
General Chat
Would you do it?
yes
3
43%
no
4
57%
Total votes : 7
Postby Red Rabbit » Sat Nov 05, 2005 4:52 pm
I figured that this might be a fun little topic. If you could afford you would you
swap a 1mzfe into your alltrac and supercharge it. I'm not talking about that lil twin screw that trd sells im talking a centifigul type with intercooler like procharger. Even though there arent many parts for the 1mzfe it would be totaly unique and n/a not to mention fast as s**t.
Red Rabbit
Postby CMS-GT4 » Sat Nov 05, 2005 5:24 pm
SC is still FI, so it would not be NA. It might have a better powerband due to discplacement and type of FI.
I would concider a SC and laughing gas like the mr2 that won the Street car challenge a couple of years ago.
If I were to do something that elaborate I might look at some other engine options while at it.
Postby Gary » Sun Nov 06, 2005 5:36 am
and make it FWD?
93 ST185
Gary
Postby Locker » Sun Nov 06, 2005 1:03 pm
Why would you make it FWD the all trac tranny should bolt up without any issue to the V6 block. I mean the v6 tranny bolts to the 3sgte
90 ST185
Locker
Postby InitialD93 » Sun Nov 06, 2005 4:59 pm
v6 is too wide, it wont clear the rear drive part of the tranny
Dustin
1990 All Trac w/ RC bumper, converted to 93
^^^ Old project about to start a new life ^^^
InitialD93
Postby Locker » Sun Nov 06, 2005 5:35 pm
InitialD93 wrote:v6 is too wide, it wont clear the rear drive part of the tranny
Interesting... didn't think of that
90 ST185
Locker
Postby toytech » Sun Nov 06, 2005 6:55 pm
you could probably make it work with a center diff from a highlander or rx300. they are near identical to the alltrac but made for the v6. probably need a custom axle though.
toytech
Postby EricGT4 » Sun Nov 06, 2005 7:00 pm
You might have a some weight issues. It would be a lot heavier. It would be really cool to see someone do though.
1992 Alltrac - 350whp - SOLD
EricGT4
Postby Locker » Sun Nov 06, 2005 7:35 pm
the v6 is quite close to the same weight as the 3sgte as its an aluminum block
90 ST185
Locker
Postby 1stGenAllTrac » Sun Nov 06, 2005 8:21 pm
yeh i think i had a SCC or Turbo mag with a MR2/v6 swap they were going to super/turbo charge it for some god-aweful reason. they said the 3s and the 1m were close in weight.
it'd be different for sure, but what would the point be if you can get similar numbers out of the 3sgte's iron lump that's already in there.. if you wanted to make serious numbers with the aluminum block v6, it'd have to be sleeved. then toss a supercharger on it with decent flow and a truck diff (which i imagine weighs more too)..
it's so crazy it just might work
1988 st-165 :: not stock....
1stGenAllTrac
Postby SBCelicaGT » Sun Nov 06, 2005 9:16 pm
1stGenAllTrac wrote:yeh i think i had a SCC or Turbo mag with a MR2/v6 swap they were going to super/turbo charge it for some god-aweful reason. they said the 3s and the 1m were close in weight.
It's not so much the numbers, but the range of numbers. A larger engine will have a larger power band and for a street car, this is very important.
With tubular exhaust manifolds, aluminum block, and no turbo, the 1MZ-FE is pretty damn close, if not lighter than a complete 3S-GTE.
As for fitment, it would be interesting to compare the transaxle out of an AWD Highlander to see if you can swap the transfer case section over.
If anyone is interested, I'll see about snapping some photos of the underside of one for comparison purposes. My girlfriend's mother recently purchased a Highlander and we'll be visiting next weekend.
As for engine durability, from what I have seen, the only weak parts are the rods and pistons which seem good for about 300bhp. Unless you're doing something dumb, the crank and block seem to be fine all the way up to 500bhp or so. Brad's engine (Yellow MR2 that won SCC "street car challenge" last year) ending up having hairline cracks in the crank, but he was making obscene amounts of power anyway.
Adrian Avgerinos
90 Celica GT-V6
SBCelicaGT
Postby 2of81 » Sun Nov 06, 2005 9:45 pm
I see this swap as not very eaisly possible......
One problem would be getting the exhaust out of the rear head. I mean with the 3SGTE it's very hard to get my hands around the back of the engine with the center diff. So exhaust would be interesting.
Justin
1972 Corolla TE27
2of81
v6 swap ;-)
Postby GMan » Mon Nov 07, 2005 11:26 pm
I have dreamed about it.
Pat aka -Alltrac101 (and others) said it would not work. The rear bank hits
the center diff. So I gave up the dream.
The MR2 board is the place to read up on v6 swaps.
http://www.mr2oc.com/showthread.php?t=139142
V6 mr2 VS. mr2 turbo stock???
http://www.mr2oc.com/showthread.php?t=140573
Why the 3vz-fe is the best Toyota v6 period
As long as we are Only Dreaming...
How about a v8 swap :-)
http://www.mr2oc.com/showthread.php?t=1 ... ge=1&pp=30
There Are V6 Highlanders, Siennas and RX300s v6-awd, (auto)
So there Is a Way to cram awd and a v6 together.
Maybe (Will ?:-) come a day when Someone will solve the
Challenges and pull off the v6 5spd swap.
It is just going to take time Money and a pioneering spirit. :-)
Regards;
GMan
Postby 1stGenAllTrac » Tue Nov 08, 2005 12:27 am
well the TTE cars were making ~300hp and gobs of torque (700+ if i recall, or i might just be hallucinating again) so i wasnt just speaking in peak HP #s.. I also had an article in a Turbo magazine with the 3sgte in a supra JGTC car in lieu of the 2jz , since they saved weight, could slide the weight behind the front wheels, and ended up with similar engine output .
.. and i wasnt trying to say its not interesting either. I'm going to go read those links on the mr2 forums for curiosity's sake. :P
1stGenAllTrac
Postby SuperWhite92 » Tue Nov 08, 2005 1:10 am
That MR2 turned out badass. It was a V6 with nitrous and a supercharger and a turbocharger. They had enough extra parts in the frunk that they could switch the ECU maps and the manifolds, etc to convert it to NA only, Turbo only, or SC only in about 20 minutes. The final numbers were just under 600whp in full twincharged, but nitrous free dynotime.
Shaun
SuperWhite92
Return to Club Chat
