Front LSD !!!!!!!!!!!!!!!!!!
Re: Front LSD !!!!!!!!!!!!!!!!!!
Postby Tecker184 » Wed Jun 20, 2012 2:20 am
I'm glad to see it arrived, I hope to see this work out.
90 ST185
Tecker184
Postby 4rsnduction » Wed Jun 20, 2012 11:08 pm
woo-hooo finally progress....i got cash just burning a hole in my pocket waiting for this :lol:
4rsnduction
Postby CMS-GT4 » Wed Jun 20, 2012 11:31 pm
I have been holding off on any major purchases hoping this would finally go through. Fingers crossed.
92 st185 (205 swap) | 03 350Z Track (sold) 13 Pilot 02 CRV
Postby athousandleaves » Thu Jul 05, 2012 7:36 am
Anyone have an idea as to why the KAAZ LSD for the ST182/3 wouldn't be compatible with the 185's transmission? Just a matter of space?
Kaaz 1.5 way clutch type LSD MSRP: $1175.00 USD
And yes I know we would all prefer a torsen unit however this thing apparently fits in the SW22 MR2 and the ZZW30 MR2-S so if thats the case again, why can't we use it?!
1991 Gray/Silver Camry 4WD
1992 Red GT-FOUR RC 626•1800 ..................................1992 White turbo4WD
athousandleaves
Postby DeeCee » Thu Jul 05, 2012 8:39 am
i thought it was due to the transfer case?
GT Four Adovansu "I want to enjoy the powerful and nimble agility behavior."
Elephant: http://www.alltrac.net/phpBB2/viewtopic.php?t=26687
DeeCee
Postby underscore » Thu Jul 05, 2012 1:18 pm
Cause that's a 2WD diff and we're AWD?
1987 GT-S -> rust in piece
1991 RC -> project http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=44216 "Darlinda the Tie Fighter"
1992 GT-S -> daily
2000 Cherokee -> ski hauler
1997 Prelude -> girlfriends daily/project "Charmeleon"
Postby lumbercis » Fri Jul 06, 2012 2:55 am
We wouldn't all prefer a torsen! :)
Caldina powered...
lumbercis
Postby darthripley » Fri Jul 06, 2012 3:37 am
^ exactly.
the SW20 MR2 clutch type LSD can be made to fit but I never have found out exactly how or what needs to be done.
quite a few years ago there were a couple of transmissions for sale with this configuration on yahoo japan but again, it was not really said how etc & my japanese isn't good enough to communicate with others effectively.
i'm sure it can be made to fit but i'm not sure how well it would work and/or hold up over time honestly. :shrug:
86 RN66 Hilux 4x4 Turbo Truck "Falcon" 22RTE
87 AW11 MR2 "Super 2" 4AGZE
90 ST185 Celica AllTrac "Vadar" 3SGTE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby phattyduck » Fri Jul 06, 2012 4:08 pm
athousandleaves wrote:Anyone have an idea as to why the KAAZ LSD for the ST182/3 wouldn't be compatible with the 185's transmission? Just a matter of space?
I've had them both side by side in front of me (changing an ST205 trans to a FWD E153 w/ Kaaz LSD). There is no way to make it work. Remember, in the space where the MR2 (E153) has one differential, we have TWO. The MR2 diff is standard size (a cantaloup size or so) while the Alltrac/GT4 has two fist-size differentials inside a single unit. The transfer case has no differential inside of it, just the transfer junction (ring and pinion, but no differential gears) and the viscous coupler.
Front/Center diffs together:
One diff:
Second diff:
-Charlie
'03 Subaru Impreza WRX Wagon
phattyduck
Postby bmt » Sat Jul 07, 2012 3:39 am
Thanks for that, it is nice to finally see the inside and get an idea of the problem. Do you have a E153 lsd you can place side by side with E154 diff?
Living the good life in New Zealand!!
bmt
Postby athousandleaves » Sat Jul 07, 2012 5:14 am
Thanks for the pics Charlie!
So it's a diff inside a diff and seeing as doing the install of this new upgraded front diff will require ripping it all apart I might as well begin saving up for that upgraded viscous coupling that Mario had figured out and do both of them while I'm in there.
It's only money! :rofl:
athousandleaves
Postby bmt » Sat Jul 07, 2012 5:22 am
Have you got more info on "Mario's upgraded viscous unit"?
bmt
Postby CMS-GT4 » Sat Jul 07, 2012 10:27 am
Dif in a Dif? Difception? After spending some time understanding how one turns the other, you can see why a standard fwd diff will not work. To be made to work,you would need some parts made. On top of that, you would have to find a small enough diff.
Postby athousandleaves » Sat Jul 07, 2012 2:36 pm
bmt wrote:Have you got more info on "Mario's upgraded viscous unit"?
viewtopic.php?t=19378&view=previous
€590+shipping to Austria...
athousandleaves
Postby YerRandO » Sun Jul 15, 2012 7:16 am
This might help better explain our center differentials
http://www.alltrac.net/phpBB2/viewtopic.php?f=43&t=44912
1990 Alltrac -white: Restoration phase
1994 GTS -black: Sold
-James
YerRandO
Return to Drivetrain Central
