Rear diff mount is finally off
Postby smog7 » Tue Dec 05, 2006 1:25 am
Im finally going to remove the messed up rear diff mount on my car, i have the instructions printed out, and the ass of my car is sitting on car stands in the garage. just wanted to see if anyone has any useful tips? what are the required torque values for all nuts & bolts?? where can i find them?
-omar
rally tarmac 1990 st185
smog7
Postby briscoe_st185 » Thu Dec 14, 2006 10:22 pm
alright mate hope this helps if u hav't already done it!
www.gtfours.co.uk
check out the how to section really helped me do mine its a piece of cake
briscoe_st185
Postby smog7 » Fri Dec 15, 2006 12:59 am
well i started the removal of the old diff mount today... 2 of the bolts on the crossmember are reeeeeaaaly stuck. i couldnt get them so i sprayed the shit out of them with liquid wrench... going to let them sit over night and have at tomorrow. anyone have any other tips?
-omar
smog7
Postby Denver_whiteST185 » Fri Dec 15, 2006 1:05 am
PB blaster and a good breaker bar will take those bolts...
I used a box end wrench on one of the bolts at the end of the drive shaft to help pivot it...
^Ted^
Denver_whiteST185
Postby smog7 » Mon Dec 18, 2006 6:38 pm
i still cannot get the last two bolts off of the crossmember. they go down about half way, but then they get super tight. im afraid that if i force it i might cross thread it or simply break the bolt.... ive been soaking the shit out of them the past couple of nights with liquid wrench.. i guess i better step up to something more powerful. anyone have any experience with the same problem?
-omar
smog7
Postby Balagast » Mon Dec 18, 2006 7:17 pm
"PB blaster and a good breaker bar will take those bolts...
I used a box end wrench on one of the bolts at the end of the drive shaft to help pivot it... "
PB Blaster is so much better than liquid wrench. I've tried both, but nothing seems to do the job quite like PB Blaster... I'd give that stuff a whirl.
1990 All Trac - Red (Down but hopefully not out)
Balagast
Postby ___Scott___ » Mon Dec 18, 2006 8:41 pm
alltrac7 wrote:i still cannot get the last two bolts off of the crossmember. they go down about half way, but then they get super tight. im afraid that if i force it i might cross thread it or simply break the bolt....
Rust and crap build up in the threads as you loosen, and eventually lock the bolt/nut. Tighten it again (not tight, but enough to back the bolt/nut away from the build up of dirt/rust) clean the threads and try agian. Repeat if necessary.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby smog7 » Tue Dec 19, 2006 2:27 am
i finally got the sons of bitches off! :D
-omar
smog7
Postby Denver_whiteST185 » Tue Dec 19, 2006 2:34 am
congrats. what are you replacing it with?
^Ted^
Denver_whiteST185
Postby smog7 » Tue Dec 19, 2006 2:52 am
im going to replace the rear diff mount.... i cleaned off all the gunk from the crossmember. think i might have shaved off almost a pound :D looks brand new now. also my rear diff and most of my undercarriage have some light rust and gunk on it, would it be wise to clean it and then spray with some rust protective spray?
-omar
smog7
Postby Denver_whiteST185 » Tue Dec 19, 2006 2:58 am
I know your replacing it, but are you going with an OEM one or an aftermarket peice?
^Ted^
Denver_whiteST185
Postby smog7 » Tue Dec 19, 2006 4:09 am
either the oem piece or the c-one one :shrug:
-omar
smog7
Postby Meurz » Tue Dec 19, 2006 12:45 pm
Or J-Speed, but it seems to be the same as C-One. :)
Turbocelica.nl
Meurz
Postby smog7 » Tue Dec 19, 2006 9:32 pm
yeah... now im really going to have to get some pb blaster for the diff bolts...
-omar
smog7
Postby bigacuralvr » Tue Dec 19, 2006 10:34 pm
PB is about 2x as much as WD40, but works about 10x better/faster! Good luck, take some pics, and let us know how it goes. (I still need to do mine...)
Brett
1990 Celica AllTrac Turbo - Sold to a new home :(
1999 Yukon - Family Mobile
2000 Dakota Club Cab - Snow Machine
2006 Scion xB - Pimp Box - HP2BSQR
2000 GSXR - Go Fast on 2 Wheels
bigacuralvr
