ST185- rear axle movement and clunking
Postby ruffneck » Thu Dec 28, 2006 11:18 am
HIya....so I've noticed a clunk coming from the rear of the car whenever you get on the brakes, at first I thought it WAS the brakes, but under the car on the weekend having a look around, I notice the rear axles have what seems to be alot of in/out movement - and when you pull on the rear axle, I hear the clunk as it moves out. It comes out by about 8mm, don't know if that is normal? The clunk is really metallic, and definitely getting louder and more frequent quickly. I know the driveshafts are supposed to have some movement, but I can't figure out why it would clunk whenever I put on the brakes - why would that cause the axles to pull out and make the clunk sound? ( the rear diff mount is brand new toyota, and urethane filled too btw)
ruffneck
st185 that's getting there
melb, aust.
ruffneck
Postby alltracman78 » Fri Dec 29, 2006 1:05 am
Your diff might be going bad.
If it has play between the teeth, it will clunk on acceleration and deceleration.
If it is this, you either need to replace it or have the lash adjusted.
The driveshafts are supposed to slide in and out.
This is how they adapt to the suspension going up and down.
Postby ruffneck » Fri Dec 29, 2006 5:11 am
yo...it doesn't clunk on accel or deccel, just on braking, and you really only hear it when travelling at around walking speed..then it's pretty loud. It really couldn't be the brakes, everything is tight, and no real room for movement?
ruffneck
melb, aust.
ruffneck
Postby CDN-GT4 » Fri Dec 29, 2006 5:16 am
Check out your suspension bushings, it's common for MR2's with worn out radius rod bushings to do that. I'm not sure if the Celica is the same or similar, but it might be worth a check.
CDN-GT4
Postby ruffneck » Fri Dec 29, 2006 5:32 am
radius rod would be control arm? Now we're talking...I hear what you're saying, mine is kinda the opposite...I put in new Superpro polyurethane bushes in there a couple of months back, and come to think of it, the noise started not too much after as I recall...and has been getting louder?? Maybe too much or not enough movement in those bushes..
ruffneck
melb, aust.
ruffneck
Postby CDN-GT4 » Fri Dec 29, 2006 5:38 am
Or maybe a loose fastener? I've read that they should be rechecked some time after things have been apart.
CDN-GT4
Postby Stubble » Fri Dec 29, 2006 5:48 am
My new favorite bit of advice for clunks is the swaybar endlinks, although you would notice that clunk over bumps, and not just during braking. Still, easy to check - grab the sway bar and try to move it - you can feel free play in the endlink.
Brady Ryall
1990 ST185 Red - parts
1990 ST185 Black
1999 Miata
2008 A3 Quattro S-line
Stubble
Postby ruffneck » Fri Dec 29, 2006 6:00 am
good stuff guys, I'll check those on the weekend...keep em coming!! I'm hoping it's nothing too serious....I had sworn no more money on the car :twisted: of course, yeah right.
ruffneck
melb, aust.
ruffneck
Postby alltracman78 » Fri Dec 29, 2006 4:10 pm
Put the rear end in the air and turn the rear axles back and forth hard.
If you hear the clunk, it will be either the rear diff, axles, or brakes.
If not [and you can check these first] it could be suspension bushings, diff mount bushing, or rear subframe bushing.
If you just replaced ALL the rear suspension bushings with new ones, they would not be clunking.
Unless you didn't tighten a nut/bolt enough of course.....
Postby ___Scott___ » Fri Dec 29, 2006 6:15 pm
Don't overlook the spherical bearings. There are four of them (two on each side), and they do get loose over time.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby Kyoto » Fri Jan 19, 2007 1:20 am
With 230awkw+ i reckon your diff is going Andy. :wink:
Tim // Melbourne, Australia
1986 ST165. 152,000km on chassis
ST205 WRC engine / IC system / rear LSD with 82,000km
Blitz K1-380V
Apexi Power FC
Aussie 3" dump pipe to 3" catback system
TWM short shifter.
Whiteline front strut brace
Kyoto
Postby wizzards581 » Fri Jan 19, 2007 2:09 am
mine has 9x,xxx miles and it gives a clunk sound during instant acceleration or deceleration. mechanic said its a worn out diff... loosen? maybe.?
-03 matrix XR
wizzards581
Postby ruffneck » Fri Jan 19, 2007 9:00 am
Hiya Tim! you're right, pretty sure it's the diff... :(
ruffneck
melb, aust.
ruffneck
Postby BoostedBlueToyotas » Sat Jan 20, 2007 2:30 am
wizzards, your problem definitely sounds like a worn out rear differential
cushion
Tim Plessing
Columbia, MD
BoostedBlueToyotas
