tranny oil and rear diff oil
alltracshoak
Active member
i think im running the redline 75-90ns on my tranny and it shifts great..perfect with no grinds at all...yes 5.5 qt..so be sure to get 6 qt.
A
Anonymous
Guest
Is there a breather hole on the diff that will leak out the gear oil if it was filled with too much gear oil?
The seals on the diff were changed and now car drips gear oil once its driven.. The mech said that he thinks too much oil is in the diff and it would soon run out to the correct level. He put in almost 2qts
A
Anonymous
Guest
smog7":m1pwkc3u said:
thats too much. all you need is 1.2qt. You might need a new washer if its dripping too much.
Thanks for the info, so it might just be that there is too much oil. The seals are brand new, so I figured they werent the issue. Which washer are you referring to?
Top
