How to replace the rear diff mount (pics)
Postby Meurz » Mon Jan 15, 2007 12:29 am
I fitted my C-One rear diff mount today, so naturally, I took pics! :)
I was able to use the 2 post lift at my mates work, which makes this mod a LOT easier I guess. I don't want to think about the idea of doing this with the car on the ground.. :wink: To get the old diff mount out, the diff needs to be moved forward and slightly downwards a bit. First step was to soak 14 bolts in WD40:
There it is, the stocker (unbolted already in this pic):
While unbolting the diff itself, I noticed the holes in the diff case are significantly larger than the bolts which go through it. Therefore I marked the diff and chassis to prevent vibrations (and stress in the drivetrain) caused by a wrongly aligned diff later on:
With the help of an extra support we lowered the diff a little bit so I could wiggle the stock mount out.
OEM vs. C-One (Looks nice and beefy):
Next up; slide the C-One mount in, raise the diff and bolt all parts up again. The new mount in place:
And what a difference it makes! When I lift off the throttle when driving, there are no nasty clunks and weird sounds anymore. All good for the next couple of years and km's! 8)
Turbocelica.nl
Meurz
Postby smog7 » Mon Jan 15, 2007 12:42 am
That thing does look beefy!! I cant wait to get mine
-omar
rally tarmac 1990 st185
smog7
Postby 2RM » Mon Jan 15, 2007 12:42 am
Nice man! Very good right up. All of us who are to do the rear diff mount later thank you in advance. :)
2RM
Postby Meurz » Mon Jan 15, 2007 12:45 am
I'll put an extended version with more detailed steps on my website. :)
Turbocelica.nl
Meurz
Postby smog7 » Mon Jan 15, 2007 12:46 am
just wondering but around how much time did it take you?
-omar
smog7
Postby Meurz » Mon Jan 15, 2007 12:49 am
Just short of an hour, it wasn't a race.. I just had a nice time with Carlos :D , checked everything twice, etc. Relaxed. :smokes:
Turbocelica.nl
Meurz
Postby grip addict » Mon Jan 15, 2007 4:11 pm
awesome writeup! does the car feel different at all around corners and such?
i need to warn everyone-
grip addict
Re: How to replace the rear diff mount (pics)
Postby all-trac's plus » Mon Jan 15, 2007 5:36 pm
Meurz wrote:I fitted my C-One rear diff mount today, so naturally, I took pics! :)
OK, nice job as always. Question, where can I purchase the C-One mount?
Thanks,
Tony
CA All-Trac
all-trac's plus
Postby Highway » Mon Jan 15, 2007 6:08 pm
2RM wrote:Nice man! Very good right up. All of us who are to do the rear diff mount later thank you in advance. :)
+1 :D
Cheers! Highway
former car....Red 91 ST185 AllTrac # 666 "SATAN"
Greddy Turbo, Blitz ECU, RC/CS upgrades....+++
now a 97 BMW 840CI...I miss the AT!
Highway
Postby toayoztan » Mon Jan 15, 2007 8:35 pm
ourall-trac wrote:OK, nice job as always. Question, where can I purchase the C-One mount?
Thanks,
Tony
http://www.bulletproofautomotive.com/ca ... hp?ID=3427
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby smog7 » Mon Jan 15, 2007 9:27 pm
greenline motorsports has it for cheaper...
http://www.greenline.jp/catalogue/bccat ... drivetrain
-omar
smog7
Postby smog7 » Mon Jan 15, 2007 9:34 pm
hmm bulletproof states that they will beat any price.. maybe i can get my mount for even cheaper :smokes:
-omar
smog7
Postby furpo » Mon Jan 15, 2007 10:53 pm
:D Yes it is a mission doing it with the car on the ground.
Roger
furpo
Postby Rick89GTS » Tue Jan 16, 2007 3:04 am
furpo wrote::D Yes it is a mission doing it with the car on the ground.
Roger
I pulled my rear diff with just jackstands, lying on my back. It actually wasn't as hard as you might think. So there's hope for all of us without access to a proper lift :) BTW, nice write up with excellent pics.
Rick89GTS
Postby smog7 » Tue Jan 16, 2007 4:26 am
i also did mine on jackstands. it just takes a little longer, and you might get some rust/crap in your face.
-omar
smog7
